Construction Tips Construction techniques and tips
LED mounting
LED mounting
Old 2nd May 2013, 12:28 AM   #1
t4ckleb0x is offline t4ckleb0x  United States
Default LED mounting
Everyone likes nice shiny LEDs on their gear! What are the different ways you guys have used to mount the LEDs on the chassis?
I made and LM3887 dual mono amp. I have been trying to find a good way to mount the LEDs, one for each power supplies, to the chassis. I have a bare face, just two 1/64" holes evenly spaced for each supply. The goal is to have the LED behind the hole but not right on top of it.
Any suggestions?
What other methods do you use for other types of lighting?
Mods, if there is a similar thread please merge.
Sent from my DROID RAZR
Old 2nd May 2013, 01:22 AM   #2
ezavalla is offline ezavalla  Argentina
ezavalla's Avatar
I usually try to get the so called "cylindrical Leds" as in the picture:
I you get those leds, mounting them is dead simple: just a hole with the righ diameter and a couple of drops of glue to fix them at the same level as the surface of your box.
Old 2nd May 2013, 01:36 AM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You can buy bezels for LED's.
Most electronic suppliers sell them.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 2nd May 2013, 01:37 AM   #4
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
I drill a tiny (1mm) hole from the front and then a suitable one from the rear leaving 1-2mm of the original 'pilot' hole. That way the light is visible but not too bright and noticeable.
Hope they might help?
If I'm not making noise, I'm making something to make noise
Old 2nd May 2013, 01:46 AM   #5
tauro0221 is offline tauro0221  United States
You can use led mounting clips. Do a Google "Led Mounting Clip".
Old 2nd May 2013, 02:03 AM   #6
sofaspud is offline sofaspud  United States
sofaspud's Avatar
For one of my recent projects, I seriously considered making a small hole in the front panel and attaching a clear plastic "window" on the rear side. The LED was then to be PCB-mounted with the rest of the circuitry, creating just a glow in the window. Seems like a workable idea. I ended up, though, just using a LED mounting bezel. About 2mA was enough illumination so it is easily seen under-lights/in-daytime, although it is just a grab bag standard 5mm green LED.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 2nd May 2013, 02:35 AM   #7
What is your source on these? Looks like what i am looking for, mounting flush to the rear of the panel .
Old 2nd May 2013, 02:58 AM   #8
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
I always use these R9-104L by Shin Chin. Very handsome and they come in a wide variety of colors. Mouser sells them.
Old 2nd May 2013, 03:18 AM   #9
If I could I would try and get laser perforations a la Apple products, but I feel like that would be cost prohibitive.
Old 2nd May 2013, 01:25 PM   #10
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
LED mounting
t4ckleb0x:
On several projects that involved HiFi2000 enclosures with 10mm front panels, I have drilled (or had Front Panel Express drill) a 3mm hole most, but not all, of the way through the panel from the rear face. On the front side, I have drilled a 1mm hole. Gluing a 3mm LED into the rear of the front panel is easy, and the small hole on the front is just large enough to be noticeable.
The photos show my daughter's LM3886 amp. There are LEDs mounted behind the knobs for backlighting and another above the switch.
Scott
Good decisions are derived from experience; experience is derived from bad decisions (unknown)
also, "Everyone has a plan, till they get punched in the mouth" (Mike Tyson)
LED mountingHide this!Advertise here!
Rockford Fosgate BD1000, green led & protect led lit. djmdp Car Audio 5 10th October 2012 04:57 PM
LED Flashlight (SUPER LED BL-X8600) with power P = 3W otherwise adorn751 Everything Else 1 9th April 2012 04:01 AM
Indicator LED mounting i thick front panels NicMac Parts 6 11th August 2009 05:33 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
