Construction Tips Construction techniques and tips
Question for an Audiophile on system connection?
Old 31st May 2013, 11:05 PM   #21
jeffjeremy is offline jeffjeremy  United States
'BUMP'
Latest additional equipment added; 40 year old like new Rotel RP2500 Teak plinth beltdrive S-tonearm turntable for my vintage Pickering XV15/400D MM cartridge, Philips CDR785 recorded with 3 disk-cd player & Pioneer Elite series DV59AVi DVD single for DVD-A & SACD compatibility...
Plus I already had a Sony MD recorder unit with additional travelmate unit for digtal CD/vinyl quality recordings on the go. Thats why I'm runn'in three pre-amps thru a passive attenuator box.
Jeff
Old 26th July 2013, 05:36 AM   #22
'BUMP'
Latest additional equipment added; Mitsubishi dual/mono 10 series pwr amp with matching pre, 20 series FM tuner & full auto Mitsu TT plus a Pioneer p-751 DD turntable. Looks like the vintage Rotel RP-2500 is out, to bad just checked it out recently with the Pickering XV15/400D and it sounds nice with just the Mitsu amp/pre & the tube buffer...
Old 13th August 2013, 04:09 AM   #23
Major problem discovered during early stage hook-up. Apt Holman preamp will only pass a very weak signal from all inputs! Damn paid top dollar for this unit because it was "trouble free" & check out buy pro's with the prior owner. It has not been in use for the past approx. five years, any suggestions for a likely issue I might be able to find and fix...
Any help would be very welcome I am not much of a knowledgeable individual when it comes to electronics! Whats the most likely sub-system at fault that I could have checked out first. You know how expensive diagnostics are these days.
Any responses welcome!
Thks Jeff
Old 13th August 2013, 04:32 AM   #24
dangus is offline dangus  Canada
One of the basics of troubleshooting is to narrow down the location of the problem by signal tracing and signal injection. If it has a tape monitor loop, first make sure the switch is in the correct position, since that might account for a very weak signal. Then see if sound comes out of "tape out" when inputs are selected. Something like an old ghetto blaster with line level inputs would be suitable. If you get sound from line level inputs, but not the phono preamp (assuming the unit has passive switching), that suggests a power supply problem.
If there are cables inside the preamp that go into plugs rather than being soldered, try unplugging and replugging them. Also, work all the pots back and forth a bunch of times, and any switches that are in the signal path. I've come across intermittent connectors and pots and switches before now, usually on Japanese stuff. I have also seen connections that someone forgot to solder; those can work fine for years, then become intermittent. Cold solder joints are also a possibility, but not a common problem in my experience.
Does it have a fuse? If it has a power cord that plugs in, is it seated all the way?
Old 13th August 2013, 04:50 AM   #25
Dangus Thks
I have a basic setup ready now, so I'll plug a cd player into the tape loop input and connect the tape out to the amp if I get good signal then I'll try both the CD and phone inputs again from the main output and the tape record position output RCA's. First I'll look around inside I just assumed if a fuse was blown I'd get no signal not even a weak one from the main outputs. Probably a bad assumption.
Will have to make time tomorrow and I'll get back to you...
Thks again for the feedback.
Old 20th August 2013, 12:17 PM   #26
Seems to be work'in again properly...
Old 23rd August 2013, 06:34 AM   #27
gmphadte is offline gmphadte  India
KISS
I prefer a simple block drawing for understanding the setup. Quick and easy.
Gajanan Phadte
Old 23rd August 2013, 07:05 AM   #28
Hello KISS
Is there a free software online that you are aware of for knocking out a quick fairly complex
multi source, bi-amp multi spk sys.
Old 30th August 2013, 07:13 AM   #29
Nope Apt Holman is definitely not pass a left channel signal from any input, still have not opened the case. Tried to work out any signal by fool'in with the knobs and sw...
Old 9th September 2013, 05:21 AM   #30
Finally testing with two stereo amps driving separate (full signal) main spk sets. From a (Yamaha 80 pre with dual RCA output sets).
Also have to test out a dual 8" pro sub-cabinet, each 8" sub will have its own amp channel supporting the dual set L/R main spks towers. Later the main twr sets will have a Hi-side/low-side signal set divided between the two individual spk cabinets per set as listed above.
Looks like the sub woofers will probably have a 250hz low pass setting. But given the choice I'd like to try 300hz. However maybe lwr like 200hz; because the Yam NS500 are supporting the main (low stereo signals) and they have 12" carbon-fiber woofers with great bass but they can get boomy way down low...
Opitions welcome on some of these active crossover limits, the main hi-pass Zu Union spk set with a bottom freq. 500hz; the Yamaha NS's set from 150hz up thru 12,000hz, these can also be a little harsh way up also; then the sub unit, set @ 250hz dwn to maybe 40hz?
Question for an Audiophile on system connection?Hide this!Advertise here!
Audiophile DIY 3 way loudspeaker system shlomo Multi-Way 6 18th October 2010 03:26 AM
DIY Audiophile Series: How to Make Your Own Audiophile Quality 300B Valve Amp (4DVD) scav Swap Meet 1 12th October 2009 03:14 PM
i2s connection question stephan-schulz Digital Line Level 2 25th March 2009 04:23 PM
Capacitor connection question Flyin11 Car Audio 5 4th February 2009 04:20 PM
series connection question JC951t Multi-Way 2 8th November 2008 10:20 PM
