Two LED's in one fibre optic strand - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd April 2013, 09:30 PM   #1
Default Two LED's in one fibre optic strand
I have two indication LED's in my amp project but I would like to keep it simple and have only one light in the face plate of the amp, so, my question is, is there a some kind of plastic thingy device that can gather the light from two led's and guide it into one fibre optic strand?
I have made an attempt of a drawing to show what I mean here.
Old 4th April 2013, 04:16 AM   #2
Top Shelf's Avatar
How about custom cutting a piece of acrylic then drilling it out to fit the two LED's then use a tiny amount of epoxy to hold them in the drill outs that way you can make the "optical combiner"any size you want. I know most cities have a store that sells plexiglass or acrylic panels.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 4th April 2013, 04:59 AM   #3
sofaspud's Avatar
Are you using a fiber strand or a light pipe?
If the former, perhaps a bicolor LED will work (a single 3 or 4 lead component).
If the latter, perhaps a proper angle will work (LEDs typically have ~30 viewing angle).
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th April 2013, 10:26 AM   #4
It could be better as shown.
Gajanan Phadte
Old 4th April 2013, 10:36 AM   #5
Thanks for the replies.
I meant light pipe not strand, sorry about that, I just didn't know what it was called (english is not my first language).
A bicolor led would be the best, but in this application its an indication a led from a charger (battery powered amp) indicating when its charging/fully charged, and a led voltmeter indicating level when the charger is not connected.
A smarter person than me would make it with one led, but I'm just getting into the world of diy electronics so it's simply to advanced for me at this point, so a light pipe with two sources and one lens would be perfect for me.
Shaping a piece of plexiglass together with a single light pipe might be a solution
Old 4th April 2013, 10:53 AM   #6
But finding such a light pipe is not easy it seems!
Old 4th April 2013, 10:54 AM   #7
Gajanan Phadte
I agree thanks!
Old 4th April 2013, 11:01 AM   #8
KatieandDad's Avatar
Would it not be easier just to use a bi-colour LED in the first place ?
For a short Light Trip you could use hot glue to make a moulding but the transfer characteristics would be very poor.
You could also try making a lead (as in Pb) mould which is relatively easy.
Old 4th April 2013, 11:08 AM   #9
Bi-colour LED would be better definitely, but I've taken apart a charger that I've built into the chassis and one of the led's is from here indicating charging and when it's full, the other led is a led voltmeter that changes colour according to battery level, I simply do not have the skills to combine this into one led, that's why a light pipe would be perfect for me.
Old 4th April 2013, 11:14 AM   #10
So it sounds as though you have one single LED and a second multi-colour LED already ?
Mixing multicolours together may give you some very odd results.
solid and strand wire in amp infobot Tubes / Valves 60 21st September 2011 04:27 AM
Fibre optic DAC? bacon665 Parts 1 29th June 2009 01:09 AM
Fibre optic - AT&T style (HP, Optek,...) TJF Digital Line Level 62 23rd May 2009 10:17 AM
Copyright 1999-2017 diyAudio
