Two LED's in one fibre optic strand - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th April 2013, 12:22 PM   #11
Originally Posted by KatieandDad View Post
So it sounds as though you have one single LED and a second multi-colour LED already ?
Mixing multicolours together may give you some very odd results.
The way it's going to work is the amp has a 3-way switch, first position the battery is connected to the amp and the LED voltmeter will indicate battery level by colour, green full, yellow almost drained, red needs charging etc., in the middle position the amp is off, in third position the battery is connected to the charger and the charger LED indicates when the battery is fully charged.
So there is no mixing the colours, I agree that would not make any sense.
Old 4th April 2013, 12:39 PM   #12
Then u have to cut a slot from the triangle, in the middle, lengthwise, but keep the front face intact.
Gajanan Phadte
Old 4th April 2013, 04:04 PM   #13
Could be that Mentor have what you are looking for. Have a look at their model 1294.2000 for example.
MENTOR
Old 4th April 2013, 04:25 PM   #14
MENTOR
Ahhh thanks! I'm going to check this out, I think indeed this might be just what I'm after!
solid and strand wire in amp infobot Tubes / Valves 60 21st September 2011 05:27 AM
Fibre optic DAC? bacon665 Parts 1 29th June 2009 02:09 AM
Fibre optic - AT&T style (HP, Optek,...) TJF Digital Line Level 62 23rd May 2009 11:17 AM
Copyright 1999-2017 diyAudio
