Construction Tips Construction techniques and tips
Looking for DIY Interconnect Links
Old 24th April 2013, 03:54 PM   #21
CharlieLaub is offline CharlieLaub  United States
Originally Posted by marce View Post
copper coated steel core 75ohm cable is for CATV and other high frequency signaling where skin effect comes into play, for audio I would have thought it is less than optimal, as you want the conductivity of a copper core. These types of cable are not realy for transmitting low frequency audio signals.
At audio frequencies the impedance of coax is quite low. For instance at DC, the Belden 1505A has only 10 ohms per 1000 ft (or 0.01 ohm per foot). The conductor is solid copper, not copper coated steel. I'm not sure on what basis you are making your statements...
Here's the MFG datasheet on 1505A:
http://www.belden.com/techdatas/english/1505A.pdf
-Charlie
Old 25th April 2013, 04:24 AM   #22
qusp is offline qusp  Australia
qusp's Avatar
probably a reply to the person asking the question you also replied to in post 18....
"Anyway opinions on the use of these solid conductor copper plated steel conductors?"
"sintered steel core with heavy pure copper deposit platting"
or didnt you read the post fully?
Old 25th April 2013, 11:31 AM   #23
marce is offline marce  United Kingdom
Yep Cheers Qusp
Old 28th April 2013, 03:06 PM   #24
Speedskater is offline Speedskater  United States
Speedskater's Avatar
I've been away from the forum, but two points:
1] Co-ax RG6-QS (Quad Shield) is optimized for CATV and cable TV, TV channel frequencies. It's as far from good audio interconnect cable as you can get.
2] That 75 Ohm value refers to the radio frequency characteristic impedance. It is measured from the center conductor to the shield, at radio frequencies. If you measure the characteristic impedance at DC the value approaches infinity. You can easily do this with your Ohm meter.
For good unbalanced analog interconnects, you want a co-ax cable with very low end to end shield resistance. (something that RG6-QS fails)
Kevin
Old 29th April 2013, 12:54 AM   #25
TomTerrific is offline TomTerrific  United States
TomTerrific's Avatar
Even though I'm using "respectable" speaker cables and interconnects (Kimber Kable 8TC's and PBJ's), and they sound fine, they don't have anything to do with DIY, and I think I can build better.
I'm going to try a variation of this design, at .5 Meters (Minus the ferrite core)
DIY Silver RCA Interconnect Cables
I expect them to sing.
DIY "Career" - TriTrix Speakers, "Repackaged" Tripath T Amp, Stereo LM3886 Amp, B1 Buffer, Dual Mono LM3875 Amp, Boozhound Labs JFET Phono Preamp, ER18 MTM Speakers // Trust me, I'm a musician.
Old 17th January 2014, 03:38 PM   #26
eherdian is offline eherdian
Originally Posted by SRMcGee View Post
Dan:
I don't have personal experience with them, but Chris VenHaus' website provides a recipe for silver interconnects: DIY Silver Interconnects
VenHaus sells the requisite parts, of course. My experience with his power cords (principally Flavors 1 and 2) has been very positive.
Scott
I did make interconnect according Christ VH design but using material I bought from ebay and add little improvisation.
For silver wire I bought 28 awg upocc from someone in taiwan, teflon core from local shop also other materials except 3mm cotton tubing from partsconnexion.
RCA is Eichmann cooper CuTe + WBT solder.
The improvisation I made is to cover the entire teflon core with big cotton tubing before I attached silver wire in double helix configuration which is also covered with small cotton tubing, anything else was the same according Chris design.
Sound character I describe is live and dynamic sound but smooth, good detail and good staging but still maintain the musicality. I compared with my stock Harmonic Technology Prosilway mk II, Chris's interconnect easily beat the HT interconnect, honestly no comparison.
Old 17th January 2014, 06:39 PM   #27
R.I.P.
Originally Posted by Speedskater View Post
..........a] Bill Whitlock writes that a long well shielded co-ax can have up to 23dB less low frequency noise.........
If that is what Whitlock says then it is not as simple as that.
In some situations a twisted pair performs better than coax.
regards Andrew T.
Old 18th January 2014, 12:13 AM   #28
Andrew, why and how could that possibly be?
We are talking about unbalanced analog RCA interconnects, aren't we?
Kevin
Old 18th January 2014, 07:41 AM   #29
R.I.P.
See the table of results in H. Ott.
regards Andrew T.
Old 18th January 2014, 04:43 PM   #30
From Henry W. Ott:
"Balanced vs. Unbalanced Audio System Interconnections"
Use cables with a copper braid (or even spiral copper) shield instead of a foil shield.
Use cables with the heaviest shield possible, or with double shields in order to minimize cable shield
resistance. Do not use cables with aluminum foil shields, since their resistances are much
higher. (Note: A foil-braid combination shield is fine, as long as the low resistance
copper braid is present). Also keep cables as short as possible, since this will also reduce
the total shield resistance.
http://www.hottconsultants.com/pdf_f...onnections.pdf
Kevin
Looking for DIY Interconnect LinksHide this!Advertise here!
Audiophile DIY Links swapx Everything Else 1 31st August 2012 05:52 AM
Microphonic DIY Interconnect Suggestions? neddyboy Analogue Source 6 15th June 2012 10:19 AM
Which is the best gemotry for diy silver interconnect? mbl Everything Else 37 30th December 2010 10:40 PM
here links diy schemas tadiam Solid State 4 13th March 2007 08:09 PM
DIY Cable and Interconnect site ChrisVH Everything Else 11 13th March 2003 10:43 AM
