Construction Tips Construction techniques and tips
What adhesive to use for Sorbothane?
Old 20th February 2013, 02:50 PM   #11
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I agree, just use silicone caulk.
planet10 needs your help:
Let's help Ruth and Dave
Old 20th February 2013, 09:30 PM   #12
tonyptony is offline tonyptony  United States
Originally Posted by Kindhornman View Post
CAl,
That would be entirely to easy, to follow the manufacturers recommendations! Where is the creativity in that, how will he know how to screw it all up!
Oh, so funny. In fact I went to the Sorbothane website before even posting this note, and I can't find Lord 7650 or 7542A/B in a small enough quantity for the limited use I have. On the flip side, flexible super glues don't come in a large enough size for what I need, to make them cost effective. That leaves neoprene glues; since the website made no brand receommendation for those I looked around and what most often came up seemed to be glues for neoprene wetsuits. Since I wasn't sure if that was the right stuff I thought that maybe someone out here has already tried something else successfully. But I guess that's asking too much.
Old 20th February 2013, 10:34 PM   #13
Speakerholic
Cal Weldon's Avatar
What about posts 2 & 3?
Old 20th February 2013, 10:41 PM   #14
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
You can get the 3M spray glue at most art supplies and home improvement stores in the paint department. You could always use old fashioned solvent based contact cement in the red can.
Old 22nd February 2013, 10:10 PM   #15
tvrgeek is offline tvrgeek  United States
test
Not water based, but I bet what we used to call "Black Death" ,3M weather strip adhesive, would bond to sorbothane. You want something that does not get brittle.
Old 22nd February 2013, 10:11 PM   #16
For the woodworkers out there, Gorilla glue uses moisture as the catalyst, not the air.
Old 22nd February 2013, 11:55 PM   #17
tvrgeek,
I said that earlier about the moisture in the air being the reactive component with the Gorilla glue. It isn't a catalyst per say, the reaction is between the Isocyanate component and water. This reaction becomes part of the urethane chain and at the same time is what makes it create the foamy look if you leave it exposed to the air. Water in the reaction causes CO2 to form in the reaction, we used this in foam formulations after CFC's were banned for the production of flexible foam materials.
Old 23rd February 2013, 11:05 PM   #18
I called Sorbothane. Had a very educational discussion about bonding materials with different energy constants. It turns out for my application I'd need either a bonding tape with different bonding strengths on each side (which is available for this kind of Sorbothane bonding), or no bonding adhesive at all. The technician recommended I try it with no bonding first.
What adhesive to use for Sorbothane?Hide this!Advertise here!
viscoelastic adhesive Monteverdi Multi-Way 18 12th November 2013 06:33 PM
Cheap, Fast, Turntable Isolation: Sorbothane and the Enco Surface Plate DaveThreshold Analogue Source 5 21st April 2007 03:07 AM
Has anyone tried sorbothane as a gasket to reduce baffle energy? mazeroth Multi-Way 9 26th January 2006 09:18 PM
Copyright ©1999-2017 diyAudio
