Construction Tips Construction techniques and tips
Help Adding A 3.5mm Jack To Factory Stereo
Old 15th February 2013, 02:52 AM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Yes.
I mean, I *hope* that CD player puts out analog audio somewhere along the path.
I wouldn't be surprised if it fed raw digital data straight into a big "do everything" chip though.
Old 15th February 2013, 04:46 PM   #12
InfiniteSleep is offline InfiniteSleep  United States
Well I've opened it up and it leads from a wiring harness through a series of other soldered points into point around the chip. I have been having trouble finding schematics on the chip, but I assume theres a few points around the chip that you could unsolder and resolder new wires into and input a new source.
Help Adding A 3.5mm Jack To Factory StereoHide this!Advertise here!
Help Soldering 3.5mm Stereo Jack DanMcQ Construction Tips 3 14th September 2012 05:30 PM
3.5mm jack replacement problems, help? fanapathy Everything Else 5 23rd July 2012 12:17 PM
(DIY) 3.5mm jack adapter to 2.5mm output Rui Luis Instruments and Amps 4 6th September 2011 06:50 AM
3.5mm panel jack hookup gychang Construction Tips 4 27th July 2011 11:43 AM
Thinn high quality Audio cable wanted for Stereo Jack plug, 3.5mm tiefbassuebertr Analogue Source 8 27th December 2010 09:04 PM
