| Construction Tips Construction techniques and tips |
#11 |
Well, I recently have been getting incredibly consistent thin micas.
But if now and then I get a thicker one, I save it in a little separate bag ... which I keep in the larger "bulk" bag anyway. Whenever I have 20 or 30 (or more) "thick" ones, whenever I am bored doing nothing , as in waiting for my coffee to brew, I split them in half. Easy to do once you practice a little. A few (very few thanks God) split unevenly , meaning a thicker half and a too thin one, which sometimes cracks. To the junkbin it goes. |
#12 |
Mount devices to copper heat spreaders that are electrically insulated from the main heatsink.
#13 | |
Regards Flodstroem |
#14 |
In the lab we use sapphire plates due to their excellent electrical insulation properties while still having high thermal conductivity - but maybe no realistic DIY option...
Rundmaus |
#15 |
The copper added to the semi increases the contact area if it is bigger and also is an immediate heatsink without the insulator, so more effective.
See my triamp. Look near the top capacitor on the left. Tri amp completed Gajanan Phadte |
| Multiple transistor heat dissipation. | Boscoe | Solid State | 3 | 22nd November 2011 10:11 PM |
| Need help: 5687 tubes and heat dissipation | Mrpong | Tubes / Valves | 6 | 20th March 2006 03:07 PM |
| CLC Question - Heat Dissipation | TwangBar | Pass Labs | 2 | 2nd February 2005 08:01 PM |
| Heat dissipation from 3875 | soundNERD | Chip Amps | 3 | 19th January 2005 01:03 AM |
| Heat dissipation | Magura | Pass Labs | 26 | 15th November 2003 12:00 PM |
