Construction Tips Construction techniques and tips
Good PolyFill Option?
Old 24th February 2013, 08:59 PM   #11
tvrgeek is offline tvrgeek  United States
Fill does two things. One is to reduce midrange reflections. My testing says the cotton stuff does that best by a tiny margin.
Second is to modify the Q of the enclosure. In a sealed box, you can often move as much as .05 or more. That may equate to 10 or 15% volume. Ported boxes are a bit more complex. You can also change the Q of a ported box, but it may have a bigger effect on the F3, and not in a good way. So yes, amount of bass, but more or less is not always clear until you test.
Most, and I use that word carefully, sealed boxes are stuffed. I would always stuff a midrange box. I usually at least lightly stuff a ported box, but I do a lot of measuring and listening. No easy answer to "just do this" I found what works in a 20L box may not work in a 2L, and a 60 is different still.
Old 6th March 2013, 03:30 PM   #12
Greg M is offline Greg M  United States
Greg M's Avatar
I have used 1/2" carpet pad glued to the inner walls. It's the stuff that is like felt, rather than foam. I use spray glue (77) and spray the wall and one side of the pad and stick it in.
G
Good PolyFill Option?Hide this!Advertise here!
Hi, and what does polyfill do? xiayu Introductions 15 17th September 2014 07:46 AM
Pass B1 Passive Buffer Preamp. A good and simple option for chipamps?. A Sanchez Chip Amps 5 2nd January 2009 06:34 PM
Is it good option? Prabot Everything Else 2 4th June 2008 11:46 AM
How much polyfill? mazeroth Multi-Way 6 31st December 2004 03:21 AM
fullrange driver for a 3-way, good option ? mbon Multi-Way 2 13th June 2004 08:39 AM
