| Construction Tips Construction techniques and tips |
Hello Guy's like I promised the first test of a home build spider -and surroundless speaker with adjustable damping ... This is only for testing there is yet a lot to do.
This is the first test so I don't have any measurements yet. On the bottom is a link to youtube if you are interested to see this in action. One question, there are resonances at the end of the cone (the edge) The intention is to put the cone into a just fitted gap so no need for the surround (this is for weight reduction). Any sugestions? A very thin alu ring, or a rubber ring glued on the end? Thx Sorry I had to remove the link. Is there some way to remove this whole thread because without the link it is pointless
#2 |
why did you have to remove the link?
#3 |
I have been advised not to disclose any more info at this point due to potential commercial interests in this design. Therefore it is not possible to give more info about this project.
Sorry for the inconvinience |
#4 |
ahhh!
well good luck in your venture. i guess i'll just have to wait until the press release! |
| I finally made a good working transistor amplifier | realflow100 | Solid State | 18 | 18th October 2012 02:27 PM |
| Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer | fakeout | Multi-Way | 5 | 11th August 2012 06:17 PM |
| First post: Full range column surround? | crapitecture | Full Range | 4 | 25th May 2006 09:25 PM |
| Finally got the single chip MC stage working | DrewP | Analogue Source | 0 | 23rd March 2003 07:52 PM |
