DIY IC: What do do with shield? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th January 2013, 04:23 PM   #1
DreadPirate's Avatar
Default DIY IC: What do do with shield?
I'd like to make some interconnects with neglex quad microphone cable. This has two twisted pairs and a shield. Should I use the two twisted pairs only, one for signal, the other for ground with shield disconnected on both ends? I have seen someone tie the shield on the source end (ie CD player) to the ground twisted pair and leave the other end unconnected. Another alternative is to use both twisted pairs for the signal and the shield for the ground. Which is best?
Old 9th January 2013, 10:46 PM   #2
Speedskater's Avatar
For unbalanced analog audio interconnects (RCA) the most important thing is a low (end to end) resistance of the return/shield. I would use one wire for the center pin and up to 3 wires plus the shield at each end to the shell.
Kevin
Old 10th January 2013, 09:24 PM   #3
Read this: http://www.canare.com/UploadedDocuments/Cat11_p35.pdf this type of cable is a waste of money on unbalanced lines. Just get a good quality single conductor cable. E
shield ic chip at analog ground or digital ground? KevinLee Digital Source 2 17th July 2012 12:15 PM
A diy modulation cable kit without a shield, normal? Nunien Analogue Source 2 4th January 2011 03:20 PM
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 02:10 PM
Have annoying noise?... want a diy shield... try this one. destroyer X Solid State 17 8th October 2005 10:52 AM
soldering DIY IC rnzr Everything Else 2 24th March 2005 04:00 PM
Copyright ©1999-2017 diyAudio
