Chassis Questions - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 30th December 2012, 01:39 PM   #11
keantoken's Avatar
Thanks for the info. I decided I would simply drill through and use M3 screws and nuts. This is intended to be a nice-looking functional amplifier, not a metalworking experiment and I don't want to make my first 50 mistakes on an expensive chassis. So I will try to stick to more foolproof methods. My chassis should arrive in a few weeks.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 13th January 2013, 11:02 PM   #12
solid is offline solid  United States
Hi Kean,
Not having much experience, I've recently been thinking about how to mount the trannies to the heatsink. After much reading, I'm not looking forward to tapping and threading. User MJL21193, however, has been preaching (to little avail) about using thread cutting screws instead.
The MONGREL (supersym II)
This seems like an attractive alternative to me...
Old 14th January 2013, 07:51 AM   #13
keantoken's Avatar
Thanks for the tip. That's definitely something I will consider. The chassis arrived today and the screws feel pretty solid, unlikely to strip without seriously unjustified torque, so I'm more confident about the thread strength of these heatsinks.
What I had the thought of doing was using M3 carriage bolts. These would prevent someone trying to take it apart from the outside, and wouldn't be too ugly. The vent slots are M5 size, and could be used for securing trafo, caps and so on. M5 carriage bolts would work well here too.
I have been trying to think of ways to mount the toroid without shorting the magnetic field. I don't have any mounting hardware for it.
Driver stage to finals newbie questions - (I hope not dumb questions) rongon Tubes / Valves 15 13th June 2011 08:29 PM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 14th December 2007 11:41 PM
Chassis Layout & PS questions Valvomaniac Tubes / Valves 3 11th April 2007 07:46 AM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
Copyright 1999-2017 diyAudio
