Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 26th November 2012, 01:19 PM   #1
henryve is offline henryve  South Africa
henryve's Avatar
Default Joining 2 Heatsinks
I want to join 2 heatsinks to form 1 wide heatsink and was thinking of using 1 thick aluminium plate to do this. Will there then be heat conduction issues if I mount the devices onto the plate instead of onto the heatsink itself? Please advice. I will be using heatsink compound when joining the heatsinks to the plate.
Photo of the heatsinks below.
Old 26th November 2012, 01:27 PM   #2
ide2003 is offline ide2003  Indonesia
I have here per side 4 heat sinks (vertical) connected with 3mm thick angle, 2sk82 on angle
it's doing fine so far. Click the image to open in full size.
Joining two MDF for the baffles qguy Construction Tips 18 16th September 2011 03:59 AM
Joining the Community BATSEARS Introductions 7 19th May 2011 06:00 PM
Another newb joining your ranks SteveVaiRules Introductions 4 28th September 2010 10:39 PM
Joining two NCT transformers Sasquatch Tubes / Valves 3 23rd February 2007 01:53 AM
Joining the T-amp community ackcheng Class D 7 19th March 2006 02:43 AM
Copyright ©1999-2013 diyAudio
