| Construction Tips Construction techniques and tips |
Hello,
This is my first post here!! Well, I’m planning to build amplifiers. But, as I’m planning to do it right, I’ll build a rectifier and a filter for the power, otherwise I’ll probably have lots of distortions. As I don’t have a good knowledge of electronics yet (I'm a sophomore in college), I’ll begin by building already designed circuits. And I need to know how to measure the distortion, the harmonics (and if there are other measures, please comment) of a circuit. I don’t know if the methods are the same for amplifiers, rectifiers and filters. And please don’t say that I’ll need to buy those expensive equipment... ![]() About the options that I have for rectifiers, I’ve seen a projects with op-amp in feedback, is it good for audio? And do you know any website, book, article, anything that you’d suggest for a beginner? (e.g. Decibel Dungeon) Thank you in advance. |
#2 |
Speakerholic
Hi and welcome. Have you decided what type of amplifier you would like to build? If so, pick a forum that meets your needs and post there.
Good luck. |
#3 |
If you want an easy start you could build a chip amp.
Most of the work is done by the chip with a few external components.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#4 |
Buy Horowitz and Hill. Read it slowly. Don't be alarmed if the later chapters look too difficult at first.
#5 | |
Chip amps are great for beginners, but you still need to be vigilant for oscillation, instability, and noise pickup. Build one and debug it and you'll learn a lot. You can check for oscillation without a scope. High pass filter- high frequency sample and hold- VOM will tell you if it's oscillating or not. And use a zobel network whether your circuit calls for one or not.
#6 |
Thank you all for the replies!!
I've found the book that DF96 indicated me. It's great, but i'll need some time to read it, fortunately my vacation is near. About the chip amps, i'll probably build one to get some experience. But my goal is to design amps, or at least analyse already designed ones, and try to improve it. And thank you, Fast Eddie D, for your construction tips!! |
| Noob needing help. | icor1031 | Subwoofers | 43 | 26th March 2011 12:41 AM |
| Guidance for a 'beginner' | fooboo | Chip Amps | 108 | 10th January 2009 11:34 PM |
| New and needing help. | Spillages | Chip Amps | 2 | 18th December 2006 05:29 PM |
| Tube Newbee Needing Guidance | TheDriver | Tubes / Valves | 3 | 10th April 2006 07:13 PM |
| Total beginner needing advice (please!) | dubheaduk | Multi-Way | 9 | 6th January 2004 05:22 PM |
