Construction Tips Construction techniques and tips
MDF Telegraphing lines under paint.
Old 17th November 2012, 11:23 PM   #1
ermat1234 is offline ermat1234  Australia
Default MDF Telegraphing lines under paint.
Have done a bit of searching on this subject, i know a lot has already been said, but i do not see a lot of info on a possible solution i am considerind to eliminate the problem.
I have just completed my cabinet construction and next stage is filling screw holes and painting. cabinets are glued pva and screwed.
I'm wondering how successfull a trench or a "V" machined over the mdf overlaps would be, and then filled with automotive bondo.
Would this eliminate the usual lines that appear on the painted joins?
or am i creating a bigger problem?
Old 17th November 2012, 11:42 PM   #2
Einric is offline Einric  United States
Einric's Avatar
Generally I try to have the front baffle be the full dimension piece to avoid this problem.
Lay the speaker down on it's back and "fill" the cracks with glue.
Do this multiple times if need be.
Then sand smooth.
After that, use drywall spackle to seal the end gran and compensate for the transition.
Old 18th November 2012, 12:13 AM   #3
I have previously on a smaller job used 2 part epoxy resin on the "end grain" that i have a supply of.
It worked ok. It did fill the "end grain" well. What do you think of using epoxy to fill the cracks, laying face up as you describe. Then skim off with bondo.
Im aiming for a dead flat paint surface.
Alternatively, what do you think of the trench idea? I have seen a postind somewhere where they used what looked like a 20 - 25 mm wide trench.
Old 18th November 2012, 12:13 AM   #4
dewardh is offline dewardh  United States
It might be quite successful if you left it that way, and treated the relief as a deliberate "detail". Otherwise, veneer . . .
Old 18th November 2012, 12:21 AM   #5
Veneering is not an option. Definitely going to paint.
Can you elaborate on the "deliberate detail" option, like a particular router bit?
Old 18th November 2012, 12:21 AM   #6
Einric's Avatar
Epoxy could get messy and hard to remove.
Just be sure to prime before painting.
Bondo works well, if you are good with it then use it.
I would maybe just get a V groove bit for your router and use an edge guide.
It should make a nice 6mm groove that shouldn't be hard to fill.
I have never heard of doing this so I would be reluctant to try it myself.
Old 18th November 2012, 12:23 AM   #7
Einric's Avatar
Use a bit similar to this.
Old 18th November 2012, 12:57 AM   #8
kevinkr's Avatar
I'm wondering whether routing along the joints would seriously compromise their strength, probably not something I would consider doing on a pair of cabinets I'd just constructed..
Perhaps a textured or faux finish would hide/disguise the joints?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 18th November 2012, 01:12 AM   #9
The MDF is 25mm with plenty of screws so my feeling is routing the joint lines would not compromise cabinet strenght.
Old 18th November 2012, 06:48 PM   #10
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
You could use a sandable primer to build up layers which will help cover joints and imperfections. It comes in gray spray can or regular paint can for rolling on. I like the color and the smooth satin finish enough to leave as-is without a topcoat...
MDF Telegraphing lines under paint.Hide this!Advertise here!
mdf paint joshuajoshua Multi-Way 16 8th September 2008 02:36 AM
Fix spray paint run on MDF box? samtny Multi-Way 6 28th January 2008 10:24 PM
Paint Cracks in MDF Painted Boxes slhijb Multi-Way 7 9th October 2006 03:24 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Paint for MDF enclosures? nrgy Multi-Way 9 31st March 2004 01:37 PM
Copyright ©1999-2017 diyAudio
