Construction Tips Construction techniques and tips
MDF Telegraphing lines under paint.
Old 18th November 2012, 07:53 PM   #11
jackinnj is offline jackinnj  United States
jackinnj's Avatar
You could use the V-groove as a design element -- or any router bit.
Why not just veneer the surface.
Old 18th November 2012, 08:19 PM   #12
jerryo is offline jerryo  Isle of Man
I would veneer the surface and then paint that. The mdf edges on the front baffle will probably always show. (expansion and contraction due to heat and moisture changes will be different across the thickness and the width of the mdf) The worst thing about mdf is any sawn/machined edge.
If you veneered the speakers in a smooth melamine it would provide a very flat and even surface to paint as long as the correct primers were used. But of course you can get some good looking finishes with melamine. Do the front baffle in melamine/formica and paint the rest! Or maybe get some really nice wood veneer for the front and then paint the rest.
Old 18th November 2012, 09:23 PM   #13
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Don't use latex paint on MDF without sealing first with oil based, or shellac, or just use oil based paint.
Old 20th November 2012, 09:49 AM   #14
ermat1234 is offline ermat1234  Australia
http://http://www.mkt-gmbh.com/alpha...pe.php?lang=en
How about this for another option. could be rebated up to the join line.
had trouble posting this link. remove the extra http:// to view.
Old 21st November 2012, 01:11 AM   #15
cochleus is offline cochleus  United States
cochleus's Avatar
The secret is in the paint. I seen a large desk made of MDF primered and three thick sprayed coats of two-part polyester. The desk was then sanded and polished to a perfect mirror finish. Make tight joints to begin, fill cracks with bondo, sand well, prime and paint. Absolutely no chance of photographing!
"It always comes down to the best guess..."
Old 21st November 2012, 07:10 PM   #16
chrisb is offline chrisb
you mean telegraphing - anyone successful with a high quality paint job on MDF speaker enclosures would likely to want to share the results with photographs
like my mind, this space intentionally blank
Old 21st November 2012, 10:04 PM   #17
cochleus's Avatar
Well, "photographing" is the term I have always heard used for that particular problem. I didn't see anyone take pictures of the desk, but it was an awesome finish. Very expensive and difficult to apply though. The spray gun must be flushed with acetone between coats.
Old 21st November 2012, 10:08 PM   #18
"telegraph" is a trade term for flaws in substrates showing through thin veneer or paint / finish top coats, the rest was a play on words - as I said, as much as it's generally not to my personal taste, a high quality paint job on MDF is something many would consider worthy to be shared
Old 21st November 2012, 10:12 PM   #19
Andrew Eckhardt is offline Andrew Eckhardt  United States
The biggest problem is it takes a lot of time. If you don't wait until the primer is completely cured, even if you sand flat before the next coat, it's gonna sink when the previous coats "dry" and shrink. If you're in a big enough hurry you can make several coats of primer still show the joint. If time is one of the things you certainly have, you can wait a couple-few 70+ degree F days before sanding a coat of primer.
Old 21st November 2012, 10:27 PM   #20
cochleus's Avatar
The finisher first applied a "wash coat", which is a primer. Then he sprayed two thick coats of two-part polyester the same day. Then, it took him two days to sand the finish out and polish it using a random orbital.
MDF Telegraphing lines under paint.Hide this!Advertise here!
mdf paint joshuajoshua Multi-Way 16 8th September 2008 02:36 AM
Fix spray paint run on MDF box? samtny Multi-Way 6 28th January 2008 10:24 PM
Paint Cracks in MDF Painted Boxes slhijb Multi-Way 7 9th October 2006 03:24 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Paint for MDF enclosures? nrgy Multi-Way 9 31st March 2004 01:37 PM
