diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Construction Tips (http://www.diyaudio.com/forums/construction-tips/)
-   -   Princeton 5F2A Scratch Build (http://www.diyaudio.com/forums/construction-tips/223517-princeton-5f2a-scratch-build.html)
Debo 13th November 2012 08:56 PM
Blank chassis
firechief 13th November 2012 09:57 PM
check out blank chassis here Antique Electronic Supply LLC
Hard part is done - all you have to do is make openings.
Lots of choices, some with a nice painted finish on steel.
Enzo 13th November 2012 11:42 PM
You hinted at it already, but I'd have to question bending a chassis from scratch. I mean OK if you want a project and the satisfaction of doing it all yourself, but commercial chassis can be had from several sources, and they come already neatly constructed, appropriate cleanly made holes already in place, and in many cases the chassis is already plated and labeled.
Debo 15th November 2012 09:53 PM
Thanks guys.
I am currently wondering whether it is necessary to obtain a steel chassis at all. I am thinking I could use a bit thicker sheet of aluminum bent into an L and mounted from the ceiling of the cabinet.
Any thoughts on this?
Copyright 1999-2017 diyAudio
