Construction Tips Construction techniques and tips
THERMOSTAT SWITCH-HEATING ELEMENT WIRING QUESTION
Old 1st November 2012, 04:06 PM   #1
teleman is offline teleman  Norway
Default THERMOSTAT SWITCH-HEATING ELEMENT WIRING QUESTION
I know this is strictly a audio related forum,but would be grateful if someone could kindly help me this question.
I am trying to construct a small "Plastic heat bending Jig" to make some ABS plastic cases. I have bought a 15mm/300mm long heating rod element & want to wire it to an Oven type-10A/250v) Thermostat/ temperature control switch. However I'm not sure how I should wire these two.
The connection details given below.
Old 1st November 2012, 04:14 PM   #2
Insulation of the mains terminations is very important.
Is the heating element for 220Vac or 220Vdc use?
Can you arrange to power up through an isolating transformer?
As to the switching.
Simply connect the switch contacts in series with the heater.
When the contacts are open the heater is OFF. When the contacts are closed the heater is ON.
But that will give quite large swings in temperature as the "system" cycles through the ON/OFF phases.
That may be good enough.
Proportional control is very much more complex. Avoid it if you can.
regards Andrew T.
Old 1st November 2012, 06:46 PM   #3
Thanks Andrew,
Yes, I will insulate the terminations properly.
Both the h. element & the thermo/switch are rated for 220v ac only
Sorry,I don't have an isolation transformer....just want to keep it simple but want to be able work saftely.
I've worked how the switch works,but still confused as to how to wire these two in series...perhaps you could direct me please?
Cheers
Old 1st November 2012, 07:32 PM   #4
DF96 is offline DF96  England
If 'connect in series' does not mean much to you then you should not be doing mains wiring.
Old 1st November 2012, 08:19 PM   #5
Speedskater is offline Speedskater  United States
Speedskater's Avatar
While the heating element should not care whether it's AC or DC the control and switches might.
Kevin
Old 1st November 2012, 11:56 PM   #6
Enzo is offline Enzo  United States
"In series" is exactly how a table lamp is wired. In the case of the lamp you have a light bulb instead of a heating element.
Old 2nd November 2012, 05:58 AM   #7
gmphadte is offline gmphadte  India
Don't electrocute yourself.
Gajanan Phadte
Old 3rd November 2012, 11:57 AM   #8
Thanks guys for all your input...however, I think I've asked the wrong question! What tripped me off ( pun not intended!) was the terminal post 1
Whats's the purpose of terminal post 1?
Is the wiring as I've drawn correct?
Old 3rd November 2012, 12:22 PM   #9
Teleman,
you are way out of your depth.
That switch is a double throw type. Sometimes described in the datasheet as spdt (single pole double throw).
It has a normally closed (NC) pair of contacts and a normally open (NO) pair of contacts.
You should have known this.
You should also have known that you can check which contacts are NC with a test instrument, or even a battery and bulb.
You should also know how to connect in series.
You should also know how to get the switch to change over.
This is all very basic electrics.
You do not learn this by experimenting with mains voltage on the LIVE side.
I suggest you get a qualified electrician to wire this up and "certify" that it is safe for your to use.
regards Andrew T.
Old 3rd November 2012, 12:48 PM   #10
+1
THERMOSTAT SWITCH-HEATING ELEMENT WIRING QUESTIONHide this!Advertise here!
Selector switch wiring littlerick Parts 2 10th September 2012 05:45 PM
Help with switch selection and wiring... illacov Parts 1 14th October 2008 05:06 PM
rectifier diode in series with AC heating element to save energy? star882 Power Supplies 18 11th June 2007 07:46 PM
Help with switch selection and wiring needed Thunau Solid State 7 12th June 2005 09:27 PM
Need help wiring DPDT switch Static1 Parts 4 14th October 2003 11:25 PM
