Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th October 2012, 05:53 PM   #1
endia is offline endia  Turkey
Default which heatsink is more efficient?
hi,
while i was searching adequate heatsinks for symasym i found these two types. i want to use them on two sides of the chassis.. which one is more efficient? which one do you prefer? thanks..
Old 9th October 2012, 06:11 PM   #2
Mooly's Avatar
Vertical fins are the best for heat dissipation because the hot air rises freely between the fins.
Strange to say that horizontal fins are used on the Sugden A21a Class A amp and that amp runs really hot. Obviously they (and the case) dissipate the energy sufficiently but it would run cooler with vertical. Maybe a rare case of form over function from Sugden.
I think the horizontal look better though
A simulation free zone. Design it, build it, test it.
Old 9th October 2012, 06:25 PM   #3
Hi Mooly, thanks..
just looked forum's gallery pages and this explains why most builders choose vertical ones.. besides horizontal look better me too
Old 9th October 2012, 06:37 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Heatsinks with pins instead of flat fins are the most effective.
If you orient fins horizontally they are useless for free convention. However you may see horizontally oriented fins when forced air is used, also forced air allows to use densier heatsinks. For free convection optimal distance between fins (width of gaps) is 8 milimeters.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 9th October 2012, 07:07 PM   #5
thank you Wavebourn,
i will use heatsinks outside of the chassis with free air, so i'm sticking to vertical placement with no doubt..
Old 9th October 2012, 09:34 PM   #6
forr is offline forr  France
forr's Avatar
The lower figure with its vertical fins looks like the front of the Quad 405.
To me, it's the best place to fit heatsinks but few manufacturers do it his way (Quad, DB systems, some old H&K and JVC, I think ).
Note that horizontal are not only less efficient, they will accumulate more dust.
Old 9th October 2012, 09:54 PM   #7
thanks forr.. indeed, that also makes sense..
Old 9th October 2012, 10:27 PM   #8
tinitus is offline tinitus  Europe
good to have 'adequate' heatsinks
but to achieve best cooling its equally important to ensure optimal heatspread by mounting the transistors in the right place
sometimes completely neglected
but then optimal cooling may not be necessary
efficient and simple 2 way rg24 Multi-Way 14 9th January 2011 10:42 PM
very efficient Heatsink for POWER AMP Stefanoo Group Buys 0 24th May 2010 03:50 PM
Efficient Glue... I need help ! ROCKMANDRAKE Planars & Exotics 1 10th January 2010 01:46 AM
Most Efficient Speakers ? EdT Multi-Way 6 18th August 2007 11:55 PM
1 efficient 12" or 2 (far) less efficient 10"s? beady Car Audio 4 8th August 2004 04:55 AM
Copyright ©1999-2013 diyAudio
