| Construction Tips Construction techniques and tips |
#11 |
Thanks guys for all the responses. I've learned the hard way both with broken taps and using oil! Now I take it slow. I like the looks of the Hand Tapper here. I think this can go a long way towards 'straighter' taps. Does anyone have experience using this particular or similar tapping gig? It looks like it would still require clamps to tightly hold the material.
redjr |
#12 | |
It's not a bad idea to chamfer the drilled hole before tapping, the tap is easier to start this way and it guides the tap into the work. |
#13 |
Speaking of drill presses...I'm about to invest in one, but I'm not sure it has a slow enough speed for tapping. It's slowest speed is 250 rpm. I've been drilling all my holes by hand, so realize it's time to step up. I don't need a big one, just a small..ish one for these types of light projects. It will make boring wider holes a lot cleaner and easier - not to mention making truly perpendicular holes in the material. For those curious, I'm looking at this one at Harbor Freight. Any thots?
redjr |
#14 | |
I've also used a clutched auto reversing taping head in a milling machine. It's a dream. Lets you tap 100+ holes/hr. For that you just hold the work piece on the mill table (yes, with your hand) and let the tap find the center of the hole. I wish I had one. It worked just like this http://www.youtube.com/watch?v=_CUGz0jXvWQ. Best, Nelson Last edited by N-Brock; 4th October 2012 at 03:15 AM. |
#15 |
You are right. The maximum height for this particular jig is 3.75". That should work for most all of what I plan to tap now and in the future.
redjr |
#16 | ||
Yes - for BOTH the drilling, and the tapping, using the below procedure. Even the cheapest hobby version will work well if the quill and table are reasonably rigid with respect to each other. It's not even essential that the table is square to the spindle if you do it like this:
Shortcut: If you have several holes to tap, you can first drill all the holes then tap them individually without losing very much of this technique's effectiveness. The key is Step 8, above, where you return the workpiece to the same orientation it had when the hole was drilled, before starting the tap. If you pay attention to this detail it won't matter if the spindle and table aren't exactly perpendicular to each other. For that matter you could even tilt the table relative to the spindle if you needed to tap a hole at some crazy angle. Quote:
An old machinist showed me this trick decades ago. I have sometimes wondered why it works, since turpentine is quite volatile (and flammable - take appropriate precautions!), low surface tension, and doesn't feel the least bit oily or slick. The best theory I have is that it has a tiny bit of resin dissolved in it, and the liquid flows into the tiniest gap, right to the cutting edge of the tap. At that point the heat of the cutting action vaporizes the liquid, leaving the resin behind as a solid lubricant. Dale p.s. It might be possible to trace the decline of Western civilization to the day they took shop classes out of the Junior High and High Schools . . . |
#17 |
Great reply Dale. So you're saying use the press to drill the hole first and continue to use the chuck manually with your hand to start the tapping for 2-3 threads. Remove tap and material and finish the tapping by hand with a t-bar. Does that pretty much sum it up?
redjr |
#18 | |
Over the years I DID have experience with some inexpensive import drill presses. Many incarnations ago an employer had one from Taiwan that favorably impressed me by how well-fitted everything was, all the sections moved smoothly, very low vibration, couldn't be made to chatter, etc. I saw another at a Thresher's show a few years back marked "Free to Good Home" - no motor; you could feel the chuck flop around when you grabbed it with your hand; and then you noticed that the chuck had a definite eccentric wobble as it rotated. The guy giving it away said the spindle was loose when he got it, but at some point it was drilling a workpiece that broke loose and the torque apparently bent the spindle shaft. Asking for personal experience and reviews, as you're doing, is probably the best way to sort the durable ones from the scrap iron - you probably can't tell much by looking at them in the retail showroom, though a smooth operating "feel" (if you can touch the thing), visual check of overall component "fit", and attention to cosmetic details might be clues to the underlying design and manufacturing quality. (My drill press is a cast-iron floor model from Sears, circa late 1970's, and I have no reason to replace it.) Dale |
#19 | |
Almost all the tapping I do is in pretty easy-to-tap materials (aluminum, acrylic, steel panels or chassis up to about 1/8") so I usually complete the entire hole on the drill press table. By the time I get the tap started into the first few threads, the job is half done so why bother changing to the T-bar? The exceptions are workpieces that are too large, or too small, to comfortably and easily hold on the drill press table. Dale |
| need a hand with TPA3123D2EVM -works with hand on ground | k2panman | Solid State | 0 | 16th September 2012 05:11 AM |
| Tapping a main toroidal | akis | Power Supplies | 2 | 8th May 2011 07:42 AM |
| Hand Tool to Form Component Leads ? | johnferrier | Equipment & Tools | 6 | 14th August 2010 02:44 PM |
| drilling/tapping aluminum | elizard | Parts | 32 | 6th March 2004 06:18 AM |
| Demagnetising Tool/Tool Demagnetiser | mrfeedback | Everything Else | 30 | 4th October 2002 11:53 PM |
