diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Construction Tips (http://www.diyaudio.com/forums/construction-tips/)
-   -   Removing the fake wood vinyl (http://www.diyaudio.com/forums/construction-tips/220586-removing-fake-wood-vinyl.html)
Bamalama 28th September 2012 02:25 PM
Hello.
Does anyone have any particular expertise or advice on removing the fake wood vinyl on fake wood speakers?
Bam
Einric 28th September 2012 10:03 PM
You could try a hot iron and a paint scraper.
tvrgeek 20th October 2012 09:31 AM
Heat gun, scraper, then you will need a solvent like GoofOff.
chrisb 20th October 2012 04:56 PM
What's the plan after the vinyl is removed? - depending on the refinishing, you might not need to remove the vinyl at all.
Cal Weldon 20th October 2012 08:56 PM
My thoughts too Chris. Sometimes sanding and using a spray shellac will prep the surface depending on what's coming next.
Jsixis 14th July 2013 10:21 PM
I use one of those vibrasonic tools, peels off the vinyl like butter.
Resources saved on this page: MySQL 18.75%
