Construction Tips Construction techniques and tips
veneer noob question
Old 26th September 2012, 11:47 PM   #1
toobhed is offline toobhed  United States
Default veneer noob question
Hi Folks,
I recently veneered my third set of speakers and am frankly disappointed in the results. I'm glad that cheaper Band-It veneer from the hardware store was used on my first two sets, but was expecting much better this time with a more expensive and nicer looking Paudak veneer.
While I've learned to build amps and speakers fairly quickly over the years, it seems finishing/veneering is a much flatter and slower learning curve.
I decided not to use the Band-It veneer trimmer this time around (horrific results on a pair of sub woofs), but instead used an exacto blade/knife. Contact cement, a scraper and iron completed this project's construction ensemble.
I'm still having problems with cross-grain cuts despite changing the blade frequently, though it looks worse in these photos than "in person." I need to improve my technique as I have 3 other sheets of nice African Bubinga, SouthAmerican Rosewood and some burl whose name I forget...yes, I went nuts at the veneer store!
I'm scoring several passes before the final cut and the only thing I can think of is that my #2 exacto blades are too pointy for cross grain cuts....should I try a rounded edge blade? ....it did feel like my blade was going over speed bumps on the paduak.
Pictured below is the easiest and best looking finish I've ever used: a jelly form of polyurethane/tong oil/mineral spirit blend which I applied once with a rag.
Despite the untidy edges, I'm glad I used nicer veneer this time as I've concluded that a mediocre/poor job with nicer veneer still looks better that that with cheaper veneer.
Any tips for better cross grain trims or anything else? I appreciate all of you whose posts I read before this most recent attempt and I hope my fourth, fifth and sixth attempts improve. Thanks!
Mario
Old 27th September 2012, 01:07 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Its quite a skill getting veneer right, the edges can be a nightmare.
This is why I use thin carpet to cover my enclosures. All the carpet edges can be turned over and neatly stapled down. So long as I get the edges straight it usually works out OK.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 27th September 2012, 04:42 AM   #3
chrisb is offline chrisb
Originally Posted by toobhed View Post
Hi Folks,
Mario
perhaps it's considered cheating, but part of my "success" is probably due to using flexible paper backed veneers, and the iron-on yellow wood glue method (yellow glue cross links and hardens stiffer than white glue, and I find makes for better work of the trimming)
for cross grain cuts I leave about 1/4" overhang, slightly crease along the edges with a hard sanding block and 150G paper to break the top surface of veneer grain, and trim off with a 2" wood chisel, slicing "down" in short semi-circular strokes - then follow up with an overall sanding and the finishing
like my mind, this space intentionally blank
Old 27th September 2012, 06:42 AM   #4
doctordata is offline doctordata  Australia
doctordata's Avatar
Default Edges
I always try to avoid the edges and use my router to cut out 19 mm ( or 12 mm ) square for 1/4 rounded edges . In the pictures of my latest Tannoys ( 3808 Puma's converted to 3839's , Sounds fantastic ! ) I used Tasmanian oak edges with the American Cherry Veneer . High gloss finish ( thanks to the wife , 6 layers and greatly improved the WAF !) They look and sound great !
Make sure your router bit is very sharp !
Cheers Rens
If you measure, you know; if you guess, you don't
Old 27th September 2012, 07:16 AM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Cut from the reverse side with the veneer resting on a firm support. Don't cut flush, but allow a mm or so extra that you can then gently sand back.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 27th September 2012, 12:32 PM   #6
kevinahcc20 is offline kevinahcc20  United States
kevinahcc20's Avatar
You might try a veneer saw like this Veneer Saw - Rockler Woodworking Tools
as you can see it is a very affordable tool that lets you crosscut very close to the mating edge and sand back to finish.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 27th September 2012, 12:45 PM   #7
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
He's right, use a veneer saw. Rockler is not the only source, BTW. They're relatively cheap, don't have a set on the teeth, and will let you cut close.
Old 27th September 2012, 07:56 PM   #8
Thank you Gents! will take these recommendations and report back when I finish veneering TABAQ folded TL. I'll try a veneer saw and even if I end up using an exacto blade, it will be rounded. I won't trim flush but will sand off the last millimeter or two.
Mario
Old 28th September 2012, 05:42 PM   #9
westers151 is offline westers151  United Kingdom
Veneer saw all the way - forget the exacto knife if you want proper cuts.
And don't forget to sand the veneer before applying the finish. I'd start with 120 grit, then move up the grits finishing with 180. You could go to 220 grit, but I don't bother as the surface is smooth enough with 180 grit. And use a sanding block.
Then brush the dust off, tack cloth to get the rest of the tiny stuff off, then apply the finish.
Old 28th September 2012, 06:06 PM   #10
Einric is offline Einric  United States
Einric's Avatar
I used a lock back razor knife.
I just allowed my contact cement to set and then flipped the speaker over on a large piece of MDF.
Then I made 3-4 passes cutting flush and lightly sanded once the final cut was made.
I used raw 1/42" veneer of multiple types and it worked well.
veneer noob questionHide this!Advertise here!
Quick Veneer Question toobhed Construction Tips 4 6th November 2011 03:50 PM
finish the plywood or veneer it - that is the question dagerman Construction Tips 4 21st October 2011 06:55 PM
Noob Question -.- fr1s Chip Amps 6 25th February 2009 06:47 PM
Noob question dumbo800 Tubes / Valves 6 12th August 2008 02:43 AM
