Discrete circuit for relay selecting help - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd September 2012, 09:45 AM   #1
Default Discrete circuit for relay selecting help
Hello. I kindly ask your help in designing a discrete circuit. It seems i am unable to make it work on my own.
I need to build a relay based source selector. I need to select the active relay using a few push buttons, each button associated with a relay. Thank you
Old 3rd September 2012, 05:50 PM   #2
Try this 4 pos. switch, easily extended to 8 or more. The 0.1uF cap across the "Off" switch asures that the unit is off on power-up. All pb-switches are momentary. Good luck! E
Old 3rd September 2012, 06:00 PM   #3
AndrewT is online now AndrewT  Scotland
Please describe how 4012 works.
Then you could follow up with the 4044.
regards Andrew T.
Sent from my desktop computer using a keyboard
can LM318 be changed into discrete circuit? rmgvs Solid State 5 26th July 2010 08:16 AM
Advice needed for selecting a speaker relay spendorspain Solid State 8 10th December 2005 11:16 PM
Relay switching circuit please jnewbold Solid State 10 3rd March 2005 07:39 AM
Discrete op amp circuit NickC Solid State 11 19th August 2002 06:50 AM
Transistor relay circuit more_power Solid State 12 21st May 2002 02:37 AM
Copyright 1999-2017 diyAudio
