diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Construction Tips (http://www.diyaudio.com/forums/construction-tips/)
-   -   Short line level signal (http://www.diyaudio.com/forums/construction-tips/217322-short-line-level-signal.html)
McDaisy 4th August 2012 12:32 PM
Im wondering.
Can I short a line level signal without destroing the source?
For example an iphone or a regular consumer cd player or a computer...
This question may sound stupid but I need to know and dont want to try it before.
Thanks!
Mooly 4th August 2012 12:38 PM
Line sources usually yes, you can. 99% of opamp outputs are short circuit proof by design.
I'm sure there must be exceptions somewhere to this and I don't know what an iphone output is like. If it's a Class D speaker output fed directly to a socket then perhaps not.
Does that help...
Enzo 4th August 2012 06:38 PM
My working assumption (always risky) is that in this day and age they anticipate the headphones jack on a portable device getting shorted as plugs are inserted and removed, and design accordingly.
jcx 4th August 2012 06:50 PM
TRS jack/plug interface sucks - it it common for the Tip, Ring to be shorted together by one of the jack contacts during plugging in/out
so any competent consumer product design using a TRS jack/plug has to survive at least momentary shorting of the channels
some op amps may have problems - especially with extended short circuited outputs
the AD8397 is somewhat popular in diy headphone amps for its 300 mA drive and rail-to-rail output swing - but it can be lunched by output shorting - if you have some current limiting the chip thermal shutdown may kick in but the output devices are too fast/high current to be saved from a low Ohm short
McDaisy 7th August 2012 03:50 PM
Thanks for you replies guys. But I still feel I havent got the anwser I want to try this.
jcx: its common the tip gets shorted while inserting and taking out but Im wondering if I short one or both channel for a longer time. What do you think?
DF96 7th August 2012 05:34 PM
You have been given wise advice, which get as close to answering your question as is reasonably possible. To give the definitive answer you appear to be seeking would require an exhaustive search through every line level source ever implemented. A competent consultant would want a huge fee for this work, and in the end would still add get-out clauses to his answer.
ChrisA 12th August 2012 10:44 PM
Originally Posted by McDaisy (http://www.diyaudio.com/forums/construction-tips/217322-short-line-level-signal-post3117828.html#post3117828)
The answer is "It depends." Likely there is over current protection built in but maybe not. The only why to know is to find a schematic for the device in question. You 'd expect some kind of short protection but maybe not.
BTW my bother just brought something over this morning for me to look at. Turns out an electrolytic cap had exploded. The designer, I'm sure in order to save 2 cents designed a power supply that would fail instantly if you put a battery in backwards. So you never know. All depends on how cheap the company building the device is.
Soundo 23rd January 2013 12:08 PM
How to mute balanced line
I've got a similar question if anyone can help.
I would like to have 4 line level outputs from a cheap Behringer mixer permanently muted, until separate momentary switches unmute them individually. Would a simple solution of a normally closed switch across pins 2 and 3 work - as with switches on mics? Or is that bad practice, as this forum suggests, for the output stage at line level? 99% of the time it will be shorted (muted).
The purpose is so a single talkback mic can communicate with 4 different earpieces individually via 4 switches. A bonus would be a fifth switch that talks to ALL (opening all 4 shorts at once)
Any suggestions before I possibly cause any damage would be greatly appreciated!
Adam
Mooly 23rd January 2013 12:32 PM
Hi Adam,
you might be better starting a new thread for this as its specific to a particular unit.
As a general guide, although shorting an output to mute it might be considered poor practice, the reality is that most opamps are short circuit proof. As always, knowing the exact circuit configuration helps.
You could always add a small resistance (say 100 ohms) to each feed to make it more "acceptable". That would help preserve DC conditions even though the output were shorted. If the outputs are AC coupled then its even less of a problem tbh.
Resources saved on this page: MySQL 18.75%
