5.1 Amp - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd August 2012, 03:55 PM   #1
Bcrary3 is offline Bcrary3  United States
Default 5.1 Amp
Does anyone know and or could help me how would one go about making a 5.1 amp? Any help would be great!
Old 3rd August 2012, 05:07 PM   #2
DUG is offline DUG  Canada
There are lots of pages already here that you could use. Look at what other people have built and see what direction you would like to go.
A 5.1 amp is just 6 amplifiers with the last one (for the sub woofer) twice (at least) as powerful as the other 5.
If you are new to electronics a kit would probably be the best route.
If you are more experienced then you can move past that to the your level.
a couple of questions that need to be addressed:
How much power? (size of room, speaker efficiencies)
What speaker impedance is to be driven?
Best help/advice: start learning by surfing, these forums as well as Google
search for amplifier schematics...you will find hundreds
search for amplifiers in images...lots there
Best advice always: get lots of advice and then decide yourself what you want to do
There are many right and wrong ways to build what you need...if it works, is safe, and you like the sound then it was the right way. If it does not work very well, is unsafe or you let the smoke out of the parts or it sounds bad then more work is required. (wrong way)
Have fun
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 3rd August 2012, 08:11 PM   #3
dangus is offline dangus  Canada
The most cost-effective solution is to buy an obsolete A/V surround receiver from a thrift store. $20 to $50, and that's for one with decoding for Dolby Digital (and usually DTS). If you have a source with 5.1 outputs (like a sound card, or DVD/Blu-ray player with internal decoding), then an older "Digital Ready" receiver should work, since those have 5.1 analog inputs. You might run across an outboard Dolby Digital processor like the Technics SH-AC300 or SH-AC500D; those were intended as companions to the "Digital Ready" receivers, but since they have built-in source switching and volume control, you could hook up 6 channels of power amplifier without a receiver.
For larger rooms, a bunch of linear chip amps like the LM3886 should work. In smaller spaces or for desktop use, boards based on Tripath digital amp chips (TA2020 or TA2024), or the Yamaha YDA148 would be smaller and simpler to work with. Tripath boards can be found cheap on eBay; Dealextreme was cheaper for a YDA148 board.
Another option: use a multichannel car amp and power it from a computer ATX supply.
And finally: collect old stereo receivers and integrated amps and use them as basic amplifiers for the main speakers or just the subwoofer.
If you want an insanely powerful subwoofer, look out for a deal on a used pro or semi-pro power amp. I found a Behringer EP2500 at a Cash Converters store for about $250; about 600 watts per channel into 4 ohms.
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Copyright 1999-2017 diyAudio
