what blade to cut birch ply? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th August 2012, 04:04 AM   #11
60 bux for an excellent blade. Crazy! I have many Freud blades. There may be some equals, Tenryu for instance, but are they Communese?
Old 4th August 2012, 05:32 AM   #12
doorman is offline doorman  Canada
doorman's Avatar
(Pardon the hijack, Canada 2, GB nil--- Olympic women's football!)
Yup, Chris's blade rec. is perfect!
Don
Old 22nd August 2012, 04:17 PM   #13
One good trick/tip I learned and works great is to score the wood with a sharp box knife. This prevents chips and tears when using cheap blade.
I use a long metal ruler to accurately score the wood.
Old 24th August 2012, 09:21 PM   #14
Agree. I was going to recommend doing this also. It works with melamine too. Even with a good blade, its hard to avoid tearing the veneer, especially when crosscutting.
Old 3rd September 2012, 06:13 AM   #15
TundraLTD's Avatar
I use this blade Freud LU79R010 on my table saw. I talked to the guys at woodcraft for a while they recommended this blade and said blades with a near neutral pitch were best for what I was doing. Between the table saw and my Festool TS75 I'm set
Old 27th November 2012, 02:57 AM   #16
dmag is offline dmag  United States
dmag's Avatar
Triple chip or best results will be had with a high alternate bevel with a negative rake angle.
More teeth is always better.
A layer of blue masking tape can help with tearout if its still a proben.
Amana and Everlast used to have very good technical refs in their blade catalogs.
And use a guige for skilsaws.
Old 27th November 2012, 05:21 AM   #17
dangus is offline dangus  Canada
I cut oversize if I'm using the Skilsaw, then do a final cut using a router with a carbide bit. On an inside edge, I'll use the router with a guide. On an outside edge, I'll leave it oversized until the box is assembled, then use a flush trimmer bit.
Warpage, Baltic Birch ply over particleboard? ro9397 Construction Tips 11 14th October 2011 02:33 PM
Birch ply in France ? mahleriana Full Range 0 7th March 2011 06:18 PM
Birch Ply in Australia jamikl Full Range 3 9th November 2006 11:50 AM
7 ply birch oachalon Subwoofers 5 12th September 2005 05:59 AM
stain for baltic birch ply? slappomatt Full Range 13 7th March 2005 10:17 AM
Copyright ©1999-2017 diyAudio
