Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 27th July 2012, 07:17 PM   #21
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
yeah ok fine whatever
why would a clipped signal, that has rms below the max sustained, damage a speaker?
Old 6th August 2012, 04:51 AM   #22
A clipped signal is like a switched DC supply. Its rise/fall time may be slow.
Gajanan Phadte
Old 29th August 2012, 08:37 AM   #23
gohar is offline gohar  Pakistan
I want to know that how a subwoofer is connected with a L+R channel??
i'm in the process of making LM3886 chip amps, one for Left, one for RIGHT and one more for subwoofer as suggested by "Mooly". My inputs are stereo cable from computer. Left amp connected to Left RCA, and RIGHT amp with right RCA but what about subwoofer amp?? As subwoofer plays both left and right low frequency signals, i am confused in how to OR where to connect subwoofer amp, i mean what is the input of subwoofer amplifier?? Left RCA? right RCA? or both Left and Right RCA??
Old 29th August 2012, 02:56 PM   #24
Mooly's Avatar
It's both
You can just combine them resistively at the subwoofer amp input. Try something like two 10k resistors one from the left and one from the right and take the subwoofer feed from the junction.
A simulation free zone. Design it, build it, test it.
Old 14th September 2012, 10:42 AM   #25
In this schematic,
if i changed Rf to 20k and R3 to 1k, what were the changes produced? As i can't able to find 22k for Rf so i decided to go with 20k for Rf. and what about the schematic? is it fully functional with original component values?
I am going to place 50k pot for Rin instead of 25k. what changes does it make?
Old 14th September 2012, 12:04 PM   #26
Mooly's Avatar
Rf and R3 work together to set the gain. The difference of 22K and 20K probably won't make any noticeable difference in practice. The actual gain is (RF + R3)/R3 Maybe drop R3 to 560 ohm if you use 20K for Rf.
The opamp will be classed as stable for "gains above xx" so make sure you don't decrease the gain to much if you alter these values.
Using a 50k pot is no problem. Thecircuit looks fully functional although I would have thought the pot wiper should be AC coupled both to minimise altering the DC offset as the pot is rotated and also to minimise noise as the pot is turned.
Old 14th September 2012, 03:28 PM   #27
And if i eliminate the pot then?
Old 14th September 2012, 03:48 PM   #28
Mooly's Avatar
then you have no volume control
Old 15th September 2012, 06:47 AM   #29
Input DC decoupling capacitor and RF attenuation is required for this? And if i change Ci to 150uF or 220 uF then?
Old 15th September 2012, 06:59 AM   #30
Mooly's Avatar
Ci works in combination with R3. Increasing Ci will extend the low frequency cut off point. If you go to big on these then you may suffer with switch on and off thumps (depending how well the LM3886 controls these).
anyone built an amplifier Distortion measurement circuit steevo Solid State 16 3rd May 2010 05:46 PM
Is there anybody built a non feedback amplifier?? lukio Solid State 600 1st July 2009 11:05 PM
Have you ever built this balanced amplifier aht Solid State 2 15th November 2004 06:55 AM
Copyright ©1999-2013 diyAudio
