Drywall screws - Not enough? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 5th July 2012, 01:01 PM   #31
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by ODougbo View Post
Metal, yes form the diagram. The metal keeps getting thiner (what a surprise there) it's hard now to set a screw down in the drywall (standard gauge is beer can thickness).
I think you are on the right track, glue studs before drywall. If you have a helper you can always get the 5/8" thick board, more work (heavy) but it is stronger.
Good point Chris about the switches/outlets, DD, do you have plastic boxes or metal?
*probably going to need helper anyway.
There's only one electrical box in there at the moment, for the vacuum cleaner. All the components are mounted in the wall in this room where my pc is. Just the faceplates stick through and the speaker terminals are surface mount, so it wouldn't be too terrible to re-do it.
It'll probably be a project for later in the year once it starts to cool down, it's been over 100 degrees here for the past few days, lugging around sheets of drywall and OSB would probably be terrible!
Thanks for the advice guys, I think what my plan is going to be is to pull the drywall, put up some OSB, trowel in a thin layer of liquid nails and then drywall over that and run some 3" deck screws through the whole mess.
Old 5th July 2012, 03:01 PM   #32
Originally Posted by DrDyna View Post
<snip>
Be careful with the big screws. You may be better off using more of the standard screws. Also be careful not to over tighten them to the point of breaking the screw head through the paper surface. Just below flush is the trick. Any deeper and the wallboard is broken and weaker.
DT
Old 5th July 2012, 03:17 PM   #33
ODougbo is offline ODougbo  United States
Maybe jump to 1 -5/8" or 2" long screws.
OSB layer, well it will help with decorating; can hang picture anywhere you want.
Oh that's right, won't be hanging pictures on that wall.
btw, they sell a "lightweight drywall" it looks the same, a bit easier.
Old 5th July 2012, 03:41 PM   #34
Speakerholic
Cal Weldon's Avatar
I would use sub floor glue on the studs when mounting the OSB and then...
I would use Green Glue to mount the drywall to the OSB. Both those glues are made for what you are trying to do.
Yes, for the reasons described. Use the fluted drywall screws. There's a reason they're made that way. They activate the clutch or your driver properly with little to no overdrive.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th July 2012, 04:22 PM   #35
DrDyna's Avatar
Thanks Cal, this will be the plan then.
Drywall cabinet lduarte1973 Multi-Way 2 2nd June 2011 10:42 AM
Screws crazycamber Parts 7 18th December 2010 01:26 AM
SCREWS - where to get them? smellygas Multi-Way 7 28th May 2008 03:04 AM
Drywall compound as MDF filler? 454Casull Everything Else 10 12th April 2005 12:32 AM
Do I have to use screws busterno1 Multi-Way 8 10th February 2004 09:58 PM
Copyright 1999-2017 diyAudio
