Drywall screws - Not enough? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd July 2012, 10:53 PM   #21
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by ODougbo View Post
The standard gauge channel is pretty wimpy - move up to 20 gauge channel-studs-track.
Do you mean metal studs? I've only used wood while building this room. They're inexpensive (probably around 3 dollars per stud) but the wall seems to be very solid, save for when I start thumping some music.
I think what I'm going to do for now is cut some 15" ~ bracing to go between the studs, as I have some left over, and the wall that's irritating me is open to the utility room on the other side, maybe shoot a few tubes of liquid nails in all the stud -> drywall mating surfaces.
Old 3rd July 2012, 11:24 PM   #22
Hi All,
The industry has been testing and building sound partitions for a while. Check out this gypsum wall board. It is stronger denser and designed to stop sound, including constrained layer and all.
http://www.nationalgypsum.com/produc...e%5C111029.pdf
Also check out this page for STC (sound rated) partitions.
STC Ratings
Follow the installation instructions!
DT
Old 4th July 2012, 07:22 PM   #23
chrisb is offline chrisb  Canada
Might we be getting carried away with the advice for advanced sound control walls ?
Frankly if it was me, and I didn't mind the couple of hours and cost of material to trash all existing drywall and start over, I'd take Evan's advice and glue/screw a underlayment of 1/2" plywood (not PB or MDF - and use Lo-Root / deck screws for the plywood NOT drywall screws), As he says it'll stiffen that wall up like crazy, and the added bonus of providing sturdy support for any wall hanging cabinets, etc. - and definitely a webbing of construction adhesive for the drywall as well.
Note that you'll need to either remount electrical outlet boxes or use extender sleeves to stay within code for all but LV wiring.
... so, not as easy at it sounds, this letting go thing
Old 4th July 2012, 07:44 PM   #24
ODougbo is offline ODougbo  United States
Metal, yes form the diagram. The metal keeps getting thiner (what a surprise there) it's hard now to set a screw down in the drywall (standard gauge is beer can thickness).
I think you are on the right track, glue studs before drywall. If you have a helper you can always get the 5/8" thick board, more work (heavy) but it is stronger.
Good point Chris about the switches/outlets, DD, do you have plastic boxes or metal?
*probably going to need helper anyway.
Old 4th July 2012, 08:07 PM   #25
to clarify my post above - I meant - "strip all gyproc and glue/screw the 1/2" ply directly to studs" - you won't need any more bridge bracing than that!
Old 4th July 2012, 08:13 PM   #26
diyAudio Moderator Emeritus
jean-paul's Avatar
Thank God bricks and cement can still be bought.
It's only audio. Member of the non modular PCB design committee
Old 4th July 2012, 08:31 PM   #27
Speakerholic
Cal Weldon's Avatar
Hey Chris, I wonder how that wall with the funky hat track compares to a party wall for sound isolation?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th July 2012, 08:46 PM   #28
well considering the number of layers and careful sealing / isolation of all joints, I'd imagine well enough for most of us not blasting at or beyond THX levels of 105dB
of course if one wanted to get fully carried away:
6moons audio reviews: The Room
page 5 is mostly the details of how this particular system ( IsoDamp) works
take it in context as to the total cost of the room / system - which I gave up trying to estimate - but must be well into the high 6 digits
I don't even want to think about what Mike would do for a "little home cinema"
Old 4th July 2012, 08:59 PM   #29
Speakerholic
Cal Weldon's Avatar
Good idea for an existing adaptation and if you were starting new you could always begin with a party wall and do it the same way. Thanks for the link.
Old 5th July 2012, 04:54 AM   #30
Hello All,
All the electronics should go on the other side of the party wall in a dedicated environmentally controlled room where all the fan and mechanical noise can be isolated from the party room and all the party animals.
All for Fun
DT
Drywall cabinet lduarte1973 Multi-Way 2 2nd June 2011 10:42 AM
Screws crazycamber Parts 7 18th December 2010 01:26 AM
SCREWS - where to get them? smellygas Multi-Way 7 28th May 2008 03:04 AM
Drywall compound as MDF filler? 454Casull Everything Else 10 12th April 2005 12:32 AM
Do I have to use screws busterno1 Multi-Way 8 10th February 2004 09:58 PM
Copyright 1999-2017 diyAudio
