Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 30th June 2012, 11:37 AM   #1
ODougbo is online now ODougbo  United States
Default Gaskets!
Not that this is mind boggling but wish I had done this years ago. I have have been using rope-caulk to set drivers for a long time; works great until its time to take the drivers back out (pulls the wood out).
First cut the exact hole in scrap wood; then sandwiched gasket material in two other scrap pieces and re-cut. Next step flip woofer over and screw down, cut around driver with care.
Gasket material is easy to fine at auto parts and ebay.
*Tip of the day: attach every thing down -solid! A lot of projects are ruined because of hurrying and short cuts.
Old 30th June 2012, 12:12 PM   #2
pinkmouse's Avatar
I like something a little more flexible, so I use thin neoprene draft excluder strip. As for fixing everything down solidly, I agree, but if it's a 15" driver or above, run some 15Hz tone through it whilst you do, it's very easy to warp the basket and get a VC rub if you tighten unevenly.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 30th June 2012, 12:34 PM   #3
neoprene draft excluder strip....do you have link?
Old 30th June 2012, 12:51 PM   #4
pinkmouse's Avatar
Sorry, no. I just buy it from my local old fashioned hardware shop. I think the glazing industry uses it as well.
Al
Old 1st July 2012, 01:03 AM   #5
I'm going to try some thin cork next, the material in the pic was gas/oil type.
Old 3rd July 2012, 05:05 AM   #6
dangus is offline dangus  Canada
I think something squishier than most automotive gasket material is needed. (The cork gaskets used for stamped valve covers and diff covers might be OK.) Closed-cell foam weatherstripping seems like a good compromise.
Old 3rd July 2012, 07:33 AM   #7
frugal-phile(tm)
planet10's Avatar
On this side of the Atlantic it is usually called "weather strip". When the driver doesn't come with a gasket, it is my goto. Stick it to the back of the bezel.
Something like this. Ny Home Despot has a selection of sizes
19/32 in. x 17 ft. EPDM Cellular Rubber Auto and Marine Weather Strip-01033 at The Home Depot
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd July 2012, 07:49 AM   #8
Did it Himself
richie00boy's Avatar
Parts express sell a proper gasket on a roll, it is very good.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 3rd July 2012, 08:35 AM   #9
I agree, however this worked nicely because the woofer is cast. The perfect fit is nice also.
The idea here was to sandwich the material in two pieces of scrap so you can use typ wood cutting tools.
Never thought to look on PE, gesh the supermarket speaker store
FS:Marantz HD-88 Midranges/Tweeters/Supertweeters/Crossovers/Gaskets/Trim Pieces Etc. dtm1962 Swap Meet 1 5th January 2010 03:39 AM
Speaker Gaskets - Woofers & Tweeters (Odin Project) Monroe Multi-Way 4 18th May 2004 04:17 PM
question on woofer gaskets... jonz Multi-Way 7 13th May 2004 12:29 PM
Copyright ©1999-2013 diyAudio
