Need amplifier construction advice (PCB/Soldering) - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th August 2012, 06:01 PM   #21
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
Originally Posted by djQUAN View Post
The first image of the diodes (J7WUo.jpg) I can see a "5243B" mark which means it's the 13V part (IN5243)
the other one (6VLro.jpg) is faint but you should see 1N5240B on it which is the 10V part.
One is IN5240B and the other is IN5243B.
So the 40B is the 10V and the 43 is 13V?
My audio and DIY blog: http://phimusic.blogspot.se/
Old 4th August 2012, 06:08 PM   #22
Rullknufs's Avatar
And btw regarding the other schottky diodes that are mounted parallell with some resistors on the back it seems like the anode is supposed to be towards the FET.
Now the only question remaining is regarding the inductor that I winded.
Does it look okay? If so I'll wind the other inductor tonight in the same way as I did with this one.
Old 4th August 2012, 08:29 PM   #23
Rullknufs's Avatar
This is how I did with the diodes on the back. Was pretty difficult to position them so to not short anything.
And you can see the four surface mounted resistors in place.
Any comment about my toroid inductor in post #22?
Old 5th August 2012, 01:51 AM   #24
Send a message via AIM to ouimetnick Send a message via Skype™ to ouimetnick
I'm not sure why they would design the board where you have to tack stuff on like that. Maybe is isn't right? Are you going by a schematic or do they have assembly instructions? Regardless you will want to power the finished product up with a variac with a DBT inline. It takes milliseconds for damage to occur.
Old 5th August 2012, 10:19 AM   #25
Rullknufs's Avatar
I'm not sure either, but many people have asked in the 41hz forum and apparently they are supposed to be mounted like that. Don't ask me why the board is designed that way.
Not going my a schematic, I can't read them :P I have no assembly instructions either. I just have the BOM and drawings of the board with the part numbers.
What is a variac with a DBT inline?
Soldering Station Advice roadlesstraveled Equipment & Tools 19 26th January 2012 07:47 AM
Soldering Iron Rant/Advice ChrisR1983 Parts 22 22nd August 2009 01:19 AM
Advice for DIY ribbon tweeter construction. Puggie Planars & Exotics 3 5th May 2006 05:53 PM
Speaker construction advice? gastro54 Multi-Way 8 6th January 2004 10:15 PM
sub construction advice paulspencer Subwoofers 5 4th November 2003 06:51 AM
Copyright 1999-2017 diyAudio
