Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 20th June 2012, 08:58 AM   #1
Send a message via Skype™ to Magnasanti
Default Voice coil
when designing a speaker what determines the voice coil wire gauge ive read that the smaller the gauge the more power handling so wouldn't you just get the smallest gauge you could find?
Old 20th June 2012, 10:47 AM   #2
rho is offline rho  Belgium
To get the desired impedance the number of windings would have to go up. This increases Mms (moving mass) and Le (inductance of the coil). This is not always wanted.
You also need a wider magnetic gap to fit the bigger coil.
So, it's not just a matter of increasing the diameter of the conductor to get better powerhandling (which is not such a very important parameter in most cases anyway).
A lot more parameters change when you do that.
Old 20th June 2012, 11:09 AM   #3
You need sufficient Voice Coil to give the desired nominal speaker impedance.
That Voice acheives it's "impedance" from a combination of resistance and inductance and mechanical capacitance.
The resistance part which is often around 70% to 80% of the nominal impedance is made up by the length and diameter and electrical resistance of the actual winding.
The number of turns and the diameter of the wire (if circular) and the material (usually copper or aluminium) must give that desired Re (the resistive component of the nominal impedance).
All of this has nothing to do with the power handling. The impedance comes first, the power handling will come later.
Old 20th June 2012, 11:37 AM   #4
frank1 is offline frank1  United Kingdom
If you really are designing a loudspeaker driver, I would seriously consider reading from somewhere else as your source is completely wrong.
Frank
2 or 3 inch voice coil? Silent Screamer Multi-Way 25 12th March 2012 09:46 AM
Voice Coil TheReaper Subwoofers 4 27th October 2011 05:11 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
Going to try winding a voice coil johnthedoctor Parts 15 1st September 2006 12:03 PM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 02:31 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
