where to place potentiometer to get volume control - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 17th June 2012, 02:47 PM   #1
sam18 is offline sam18  United Kingdom
Default where to place potentiometer to get volume control
hello there, im trying to build this circuit, its a 300watt mosfet amp but i cant seem to get it to work. also where can i place a pot so i can get volume control?
thanks sam
here is the schematics:
300 Watt MOSFET Real HI-FI Power Amplifier | EEWeb
i would like an urgent reply on this because i really want to build this amp.
thanks
Old 17th June 2012, 04:27 PM   #2
Bump
Old 17th June 2012, 04:44 PM   #3
At the output of the last stage before the Power Amplifier. But the vol pot may need a buffer to drive the intervening cable.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th June 2012, 04:48 PM   #4
sorry im new to this could you be a little more less technical :/
thanks sam
Old 17th June 2012, 05:21 PM   #5
Locate the volume potentiometer in the last stage before the Power Amplifier.
regards Andrew T.
Old 17th June 2012, 05:28 PM   #6
okay thanks, what wattage would you suggest i build for the first stage then? thanks sam
Old 20th June 2012, 06:09 AM   #7
Visit sound.westhost.com
Old 20th June 2012, 02:51 PM   #8
DF96 is offline DF96  England
"There is not one capacitor in the signal path" says the designer of that amp. Clearly he doesn't regard the usual caps at the base of the feedback network or the Zobel as being "in the signal path". Audio seems to attract more than its fair share of self-delusionists! Fortunately, when used correctly, caps do no harm.
Digital potentiometer as volume control Bricolo Solid State 35 6th January 2017 05:07 PM
Potentiometer as a volume control RRSS Construction Tips 10 31st March 2012 01:16 AM
Volume Control Potentiometer Recommendation? TheLaw117 Parts 3 18th September 2010 10:01 PM
Volume Control (potentiometer) SergeDufour Parts 1 6th December 2006 09:56 PM
Copyright ©1999-2017 diyAudio
