Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 16th June 2012, 03:09 PM   #1
Post Beolit 12-inspired Portable Audio System
I'm planning to build a replica of the beautiful B&O Beolit 12 portable speaker. The speakers will be two 3" fullrange-speakers driven by a 2x15W class-D amp. A 12v battery will power the system. The dimensions of the Beolit 12 are 23 x 18,8 x 13,3 cm. This will be the maximum size of my enclosure with all components inside(battery, amp and wiring). This is not a enthousiast hifi project, it is more of a designproject while trying to get the best sound i can get within the limits of the project. This is the components i've chosen so far:
Amplifier:
2 X 15Watt Class D Audio Amplifier Board - TA2024_Class D Amplifier Board_Audio Amplifier and other Audio Boards_Audio_Sure Electronics' Webstore (Bought)
Speakers:
Tang Band W3-881SJF 3" Full Range Speaker 264-911
Battery:
High quality New DC 12V Portable 9800mAh Li-ion Super Rechargeable Battery Pack | eBay
I am not really sure about the speakers i have chosen. My knowledge of speaker-design is rather limited. High effiency, flat responce curve and has to fit a small box are the criterias for the driver(correct me if i'm wrong). Do you guys have any suggestions for other speakers that will fit my need?
Old 17th June 2012, 07:14 PM   #2
tinitus is offline tinitus  Europe
try search the forum for 'boombox' funny word
Old 19th June 2012, 09:31 AM   #3
I've read those, and it's not exactly what i'm looking for. I want something really small and really portable. All the boomboxes out there are enormous and not portable in the way i think of portable. What i'm asking is how i can make the smallest possible speaker with the least compromises in terms of sound quality. Super hifi quality is not a goal.
Old 29th June 2012, 02:27 AM   #4
Brotaku is offline Brotaku  United States
I built the microfonkens with fostex fe127 and they are the best size:quality ratio IMHO. They are about 10"x6"x6". It amazes me how much they sound like my frugelhorns but with a little less bass. I always wanted to build a pair connected at their bottoms with a TA2020 amp and a lithium ion battery in between for a great prattle system. Use 9mm Baltic birch to make it light if you want.
Old 2nd July 2012, 02:53 PM   #5
Thank you, I will check out baltic birch. I have now bought a 6800 mah li-po battery from ebay. I hope the voltage is high and stable enough for the amplifier.
Old 3rd February 2013, 06:38 PM   #6
Small Portable Speaker Covered With Wool
I have now made this and posted it on instructables. Check it out
Portable Sound System hashmaster Construction Tips 2 29th June 2012 02:14 AM
Portable PA system renzuken101 PA Systems 14 4th November 2011 02:50 AM
TA2020 MKII Portable system Needadispenserhere Chip Amps 3 6th February 2011 07:05 PM
Inspired by Linkwitz: presentation of a dipole speaker system StigErik Multi-Way 22 20th July 2010 12:28 PM
please help with 2x12w 12 V portable audio amp BabaRoga Chip Amps 13 8th March 2006 08:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
