how would i make a large chamfer on already built enclosure ? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 17th May 2012, 11:42 AM   #11
Axminster sell some decent chamfer bits. They should do a 20mm or 25mm one on a larger collet size.
N.B. Do not try to do a full 25mm chamfer in one go. Take it down in stages to ensure a nice even finish.
Using a router is definitely the way to go. Borrow one, or rent one if you don't have one. A large 45 degree chamfer bit with serve you for many jobs over the years so try not to worry about the 25 or so price tag.
Regards.
Michael
Old 17th May 2012, 11:53 AM   #12
Axminster Part no: 666161 The catalogue says 25.4mm, but the online shop states 20mm. The catalogue is correct IMO, as you can see when you look at the changes in diameter (D41.3=X19 D47.6=X25.4)
Buy Axcaliber Bearing Guided Chamfer Router Cutters from Axminster, fast delivery for the UK
You maye be able to get something larger, or cheaper, off ebay, delivered from the USA.
Regards.
Michael
Old 17th May 2012, 02:20 PM   #13
Thanks Michael , sounds perfect and better price than I've found so far. Will order one up the end of the month . I do have a fairly decent 1/2 inch router, had the choice of the router and circular saw or a table saw when i was buying tools . B and q always do a pretty good job of cutting my wood to size , so a saw table will have to wait.
Think I've made a mistake of wiring them up now though , i'm not sure im going to want to remove them to finish them off as they sound so good :-)
Steve
What amp can make use of these large caps? siliconray Tubes / Valves 37 1st January 2013 09:09 PM
Dr. Leach Very Large Enclosure 3-Way Speaker Design semper avarus eget Multi-Way 4 24th November 2011 08:47 PM
An easy place to get an enclosure built. JZatopa Multi-Way 6 21st February 2011 12:19 PM
Very large enclosure issue... Elbert Multi-Way 34 26th March 2008 09:41 PM
Has anyone built GC into a speaker to make a self powered monitor? e.lectronick Chip Amps 22 1st October 2003 08:25 PM
Copyright 1999-2017 diyAudio
