Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 24th April 2012, 09:19 PM   #1
Default How far apart do you need to space screws after gluing?
I think I am unnecessarily putting in too many screws when screwing wood together after gluing. How far apart can you place screws? Maybe 3-4 inches?
Old 24th April 2012, 09:25 PM   #2
KatieandDad's Avatar
Clamp and glue.
The aim is to stick the panels together uniformly.
Old 24th April 2012, 09:26 PM   #3
vinylkid58's Avatar
Why not use clamps?
jeff
Old 24th April 2012, 09:42 PM   #4
Originally Posted by vinylkid58 View Post
Why not use clamps?
jeff
I do use clamps to hold it in place until I screw some wood screws in. Then take the clamps off and let it cure overnight.
Leaving a bunch of clamps in aren't an option because they are big speakers and I don't have lots of clamps to keep on the speaker(s) overnight.
Plus whats wrong with screws? It's standard practice (for DIYers) to use screws to hold speakers together while the glue dries.
Old 24th April 2012, 10:36 PM   #5
vinylkid58's Avatar
Nothing, as long as they don't interfere with veneering etc.
It is? I see a lot of pictures with clamps in them.
I realize building large boxes is a challenge.
jeff
Old 25th April 2012, 02:57 PM   #6
Simon B is offline Simon B  United Kingdom
If you're going to use screws, and I do/would, definitely put them in before the glue goes off.
Actually, pilot and countersink the upper panel, assemble with clamps, run pilots into the lower panel/screw block, assemble with screws alone, disassemble, apply glue, screw and wipe. A positive self-locating distributed-pressure clamping system.
How close together you put the screws depends on speaker type, size, weight, intended useage - ie use your skill and judgement.
If you don't want the screws to stay in there, you can always take them out after the glue's set, drill out and dowel. Though your radar signature will probably still be bad on account of the metal in the speaker.....
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 25th April 2012, 05:20 PM   #7
Lavcat is offline Lavcat  United States
Lavcat's Avatar
The point of joining cabinetry with dowels is not only strength but that there are no holes on the finished surfaces.
Old 25th April 2012, 08:59 PM   #8
Err, yes, I didn't really think he needed a stealth cabinet.
Old 25th April 2012, 11:32 PM   #9
Not sure why this isn't showing, but had email notification saying;
After hammering in the dowel and breaking it, are you able to sand off the rest to make it smooth?
Don't break it off, saw it off close in with a fine saw. Then sand.
Old 25th April 2012, 11:40 PM   #10
You don't need to leave clamps on overnight. ALso, it maybe standard practice for pro audio gear that gets thrown around and ultimately covered in duratex or similar but it's really a substandard practice.
You can always clamp one box at a time. You won't like this response, but there it is. Any fastener will be visible, including dowels.
I was so much older then, I'm younger than that now.
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
Gluing questions rbmcginnis Planars & Exotics 11 31st July 2006 05:06 PM
Gluing in T-nuts DSP_Geek Multi-Way 13 20th November 2005 07:08 PM
Wet gluing veneer tiroth Multi-Way 11 22nd October 2004 07:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
