Construction Tips Construction techniques and tips
Putting veener on cabinets
Old 20th March 2012, 03:47 PM   #21
chrisb is offline chrisb
Originally Posted by ichi View Post
I use spray contact glue 3M90. Just spray, wait for five minutes and
mount the veneer using a rubber roller. Much easier that pva glue and its dry in
just 15 minutes.
yes, but the downsides are no room for error on grain alignment, and possible incompatibility with solvent based finishing materials (stains / lacquers etc)
like my mind, this space intentionally blank
Old 20th March 2012, 04:01 PM   #22
Originally Posted by ppfred View Post
Here is a good site for DIY veneering.
As long as you know what the end result will be you could scorch the wood . For a first timer I wouln't recommend it. Been there, done that, got the t-shirt (pun intended).
fair enough - but the degree of "scorching" I'm talking about is minimal, and with a little practice, you can even use the nose of the iron to pre-score the edges of cutouts on paper backed veneer, then trim out with sharp knife and 150 / 220 G sandpaper
Old 20th March 2012, 04:12 PM   #23
doorman is offline doorman  Canada
doorman's Avatar
Hey Chris, those Frugals look great!
Is that fir veneer?
Best
Don
Oh, yes, the hot iron / glue combination works beautifully, no nasty contact cement fumes either!
Old 20th March 2012, 05:01 PM   #24
Is that fir veneer?
Best
Don
thanks, Don:
flat sliced oak with Watco Fruitwood and satin wax finish - for our friend Cal
Old 20th March 2012, 09:04 PM   #25
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Ever used the iron on method for raw veneer? I have a bunch of birds eye maple. I've been trying with a caul and clamp with partial success on some trial pieces. Unsure how it's going to go on a larger piece.
Old 20th March 2012, 09:41 PM   #26
doorman's Avatar
I usually use the paperbacked veneer, but have also used the hot-iron method for the 'raw" variety.
In truth though, I haven't done much with the latter, just a couple of projects.
Best
Don
Old 20th March 2012, 09:44 PM   #27
yes, but only smaller pieces myself (repairs to a disintegrated VPI turntable base) -
vacuum bagging or weighted cold-press (several layers of MDF cauls, and sandbags, barbells, whatever you can devise) would be my best guess for that
note that if you could attain a pure vacuum, bagging would deliver 1 atmosphere of pressure - that's 14.6bs psi at sea level or over 2,100 lbs per square foot - hard to approach with cold press and weights.
the biggest issues were chipping on cross grain trimming - it just takes an extra step with careful trimming with veneer saw and sanding block
I work with paper (not phenolic) backed veneers for a lot of reasons, the ease of iron-on process and trimming among them
Old 20th March 2012, 09:50 PM   #28
ichi is offline ichi  Sweden
I used 3M90 on my FH-3 with excelent result.
the best glue was that old hot glue made from animal hides or bones applied hot
but hard for a beginner. With hot glue you can apply heat and correct misstakes.
My dad was a carpenter making one off furniture with lots of inlays and he prefered the old school hot hide glue.
Old 20th March 2012, 10:11 PM   #29
what type of finish did you use?
One of the reasons I'm trepidatious with solvent based contact cements (unless it says latex, it's likely still solvent carrier) is that our commercial millwork shop had exactly the issue I described above. A few years ago, solvent based stain & lacquer products applied on site by a separate finishing contractor caused de-lamination of paper backed sheet veneers on paneling. Finishing first and applying with contact cement after curing didn't seem to cause the same problem.
Haven't tried that yet, or the veneer only glues like Titebond, BetterBond, etc.
Old 20th March 2012, 10:34 PM   #30
At work I have access to a press capable of over 200MPa (29,000psi) with a 8" diameter ram. Would that be enough?
Might give the cauls and cab some trouble
Putting veener on cabinetsHide this!Advertise here!
FS Morel drivers, custom CNC machined aluminum cabinets, Dayton cabinets Bronson_k Swap Meet 12 12th July 2015 08:39 PM
Prices on Pensil cabinets and microtower cabinets TWills Planet 10 hifi 9 31st January 2011 02:21 AM
putting it all together iain42 Multi-Way 0 8th October 2009 01:38 AM
need help putting a system together optomos Car Audio 2 4th April 2005 06:20 AM
Veener suppliers in UK BigMacX Multi-Way 5 11th March 2003 07:27 PM
