Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 7th March 2012, 02:13 AM   #11
GloBug is offline GloBug  Canada
Banned
You need to block sand your mitre joints, then add one strip of banding at a time, trimmed with a fresh blade.
Old 7th March 2012, 10:20 AM   #12
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Texas is a bit far....... You don't have to worry about the edge of the veneer showing. It is so thin it won't be noticeable if you don't mitre it. If you veneer first and cut the panels out second you better have a sharp blade.
http://www.evancotler.com
Old 7th March 2012, 05:10 PM   #13
chrisb is offline chrisb  Canada
Originally Posted by pski View Post
I'm not sure veneer improves anything except hubris and spousal lubrication.
who isn't a fan of the second part, but "hubris"?, really?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 16th March 2012, 03:49 AM   #14
ppfred is offline ppfred  Canada
Default Pre-glued veneer is easiest (which means best)
Get yourself some veneer that is pre-glued. Then all you'll need is j-cloth and a hot clothes iron.
If you get paper-backed veneer using ordinary carpenter's glue (the white stuff) is just as good except that you have to apply the glue -evenly- yourself. Then all you'll need is j-cloth and a hot clothes iron.
Search the internets - all manner of information & some videos to boot.
Contact cement works but is tricky - best left to someone with experience, especially considering the cost of some veneers. If you make a mistake then you're stuck with it (pun intended.)
Fred P
Believe nothing you read and only half of what you see.
Old 16th March 2012, 03:55 AM   #15
Happy wife, happy life.
Old 19th March 2012, 01:15 PM   #16
mrappe is offline mrappe  United States
what is j-cloth?
Old 19th March 2012, 03:07 PM   #17
J Cloth
Disposable towels/rags made from paper available at most if not all retailers.
Old 19th March 2012, 04:50 PM   #18
I'm still waiting explanation of why "hubris" - yes - I (think I ) know what it normally means
frankly, I wouldn't bother with the j-cloth or a linen rags when using a clothes iron - I've actually found slight scorching to be handy in outlining boundaries of cutouts to be trimmed, and since I pencil mark each cut piece for grain alignment, all that easily sands out.
Old 20th March 2012, 03:16 PM   #19
Here is a good site for DIY veneering.
Veneer Application: Iron On Veneer / PVA Glue Method
As long as you know what the end result will be you could scorch the wood . For a first timer I wouln't recommend it. Been there, done that, got the t-shirt (pun intended).
Old 20th March 2012, 03:19 PM   #20
ichi is offline ichi  Sweden
I use spray contact glue 3M90. Just spray, wait for five minutes and
mount the veneer using a rubber roller. Much easier that pva glue and its dry in
just 15 minutes.
Prices on Pensil cabinets and microtower cabinets TWills Twin Audio 9 31st January 2011 02:21 AM
FS Morel drivers, custom CNC machined aluminum cabinets, Dayton cabinets Bronson_k Swap Meet 6 7th December 2010 05:32 AM
putting it all together iain42 Multi-Way 0 8th October 2009 01:38 AM
need help putting a system together optomos Car Audio 2 4th April 2005 06:20 AM
Veener suppliers in UK BigMacX Multi-Way 5 11th March 2003 07:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
