Construction Tips Construction techniques and tips
Help With Joints
Help With Joints
Old 24th February 2012, 11:52 PM   #11
revboden is offline revboden  United States
revboden's Avatar
Originally Posted by jn229 View Post
That’s 2 replies for block bracing. The cabinet is 9.5” x 21.75” x 10” inside measurements for a volume of 1.196 cu. ft. Would block style bracing be more important then bracing with shelves front to back and top to bottom? I could eliminate one of the shelf braces giving me the needed volume for glue blocks.
I find that Shelve bracing is overkill if most of the shelf is wood. All you need is a pont of intersection running along the walls to rase the panel harmonics. Not much mass is necessary to do this as long as there are strong connections between opposing walls.
We choose to have higher resonance panels because there isn't a lot of kinetic energy at high frequencies, Therefor there isn't enough energy to excite the mass of the open section of panel.
Old 25th February 2012, 12:07 AM   #12
pski is offline pski  United States
I have started a simple two way project. My cabinet joints will be a ‘butt’ joint. I have a biscuit cutter and I am wondering if the use of biscuits would strengthen the corners? The reason I am asking is that I have not seen a project with biscuits. Any comments will be appreciated.
If you have a biscuit <plate> joiner, you are way ahead of any kind of brace (and on bigger projects, you can biscuit the braces.)
A biscuit joint with glue can make a joint that approaches the strength of a single piece of material as seen here:
https://www.facebook.com/media/set/?...3&l=6334890e9d
Screws are not needed unless there is a part you feel you may need to remove/
Paul
Old 25th February 2012, 12:18 AM   #13
jn229 is offline jn229  Canada
Thanks Paul
I was thinking biscuits had to be superior to a simple butt joint. (Enjoyed the link, nice build Paul) Thinking now of doing both biscuits and glue blocks, with single piece of wood or dowel front to back and side to side, too add additional strength.
For further information, the front and rear baffles are laminated .75” mdf and .5” Baltic ply.
Old 25th February 2012, 12:32 AM   #14
Thanks Paul
Do yourself a favor: there's no way to do glue blocks without screws on the inside. This only complicates the perfect alignment when using the joiner. The blocks must be perfectly aligned or you will have to critically sand before all the glue.
As with most things, getting someone to get the parts exact before you start will help immensely. Exactly sized parts cut with careful joining <given the built-in slip> make for enclosures that scare some.
P
Old 25th February 2012, 12:40 AM   #15
P
Oh! Wait ! I am wrong.
You could do the cabinet and glue/clamp with biscuits and then add and clamp corner braces from the top.
P
Old 25th February 2012, 04:01 AM   #16
puppet is offline puppet  United States
A little advice from an old cabinetmaker .... footballs are easy, quick, and used waaaay too much. I'm old enough to remember when they first invented this ("lamelo")
.... used to work for a high end shop in Chicago that did mostly restaurant interiors. For years they joined bar tops with dowels ... along came the lamelo and they gave it a shot on one job. About six moths later you could see every football in the millwork faces ... tops, soffit panels, etc.
The biscuits are so hard that when the surrounding panels, or whatever material is used as a substrate moves (shrinks), the biscuit stays at the same dimensional thickness. The glue around the biscuit further solidifies it's mass and adds hardness. They will telegraph their presence to the surface over time. Dowels will not. That company never used biscuits again.
Not advocating dowels in you case work here ... corner bracing, as has been illustrated by others, would be my first choice, too. A simple chamfered ripping would do wonders for strength. Assemble the joint ... let it set and add in the bracing later. Plenty of glue and a couple tacks to hold it.
Old 25th February 2012, 05:26 AM   #17
phivates is offline phivates  United States
Default biskits
What puppet says. This process was invented to adapt to the weakness of composite materials, especially chipboard, which cannot be splined or tongue and grooved like real, meaning REAL, wood. Too weak. Crappy. Not good. Bad.
This DOES apply to the latter day particle board, MDF. Use plywood. It isn't dead yet.
Sorry, just my experience. Dowels rule.
Old 25th February 2012, 04:08 PM   #18
Cloud Walker is offline Cloud Walker
Correct me if i'm wrong, but if you're struggling to add bracing due to your internal volume already being fixed, could you just add some stuffing to make the box "look bigger" to the driver? Then you've given yourself some extra room to add whatever bracing you feel is required....? Unless you've already fixed how much, if any, stuffing your using. If someone more experienced could verify/correct my idea that would be useful as i'm just a novice
Old 25th February 2012, 04:42 PM   #19
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Help With Joints
My biscuit joiner sits on the shelf. I use cleats (corner blocking) exclusively and I use square rather than chamfer strips because I install the cleat on one of the panels first. This allows for perfect alignment when you assemble your box. It is also very quick. It allows you to assemble all but the back piece with inside (blind) fasteners. I use a Brad nailer only. I find screws are slow, cumbersome and unnecessary. I even do it for test boxes. In this case I decided to fit the baffle last so in this case there are exposed fasteners on the front but the idea is the same.
The apparent bulging of the box is just the camera.
planet10 needs your help:
Let's help Ruth and Dave
Old 25th February 2012, 05:02 PM   #20
Speakerholic
Cal Weldon's Avatar
Help With Joints
Another trick for when the box is not square is to use the tape and roll method and add the cleats later. Ripping down 2X4's to get a snug fit is a bit of a job though. The top and bottom pieces are just for a bit more gluing surface for the front and back so I wasn't worried about them too much.
Here is the build thread for more pics on how it's done.
http://www.diyaudio.com/forums/multi...cal-style.html
Help With JointsHide this!Advertise here!
dead smooth joints rmcelroy Construction Tips 6 6th February 2011 02:18 PM
Router Bits for Rabbet Joints stephenmarklay Multi-Way 6 8th January 2010 10:26 AM
Finger joints vs. screw and glue PRNDL Tubes / Valves 35 21st November 2006 12:24 AM
Joints for enclosures CrisTUFR Multi-Way 14 4th June 2004 08:29 PM
How to dado angled joints?? Jer Multi-Way 3 5th December 2003 03:43 AM
