| Construction Tips Construction techniques and tips |
I'd like to repair this Audax speaker myself if possible. The magnet has become detached from the basket. I've never opened up a speaker before and would appreciate any help. Does it just need glueing back on to the basket or is there more to it?
#2 |
You will need to clean off all the old glue so it sits straight and doesnt cause the voice coil to rub.
I would reglue it but make sure the voice coil doesnt rub in the position you glue it. Speakers are made from the other way, the magnet is fixed first then shims are put in to center the magnet. Then the voice coil is entered into the magnet.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#3 |
Thanks Nigel, do you know if epoxy can do the job or is there a particular type of adhesive required?
#4 |
#5 |
#6 |
It's all up to you. Pro shops woudl not attempt it without also reconing. LIke Nigel said, they are assembled the opposite way. There is no cone yet, and they assemble the magnet and pole piece. Then the cone/voice coil assembly (without dust cap) is shimmed in place in the magnetic gap (thru where the dust cap would be), and the surround and suspension are both glued. Then when dry the shims are removed and the dust cap glued in place.
#7 |
It all makes sense now having watched the youtube video. Looks best to send it to a pro shop so that it gets centred accurately and get it reconed at the same time for a proper job. Thanks
| Help repairing a crossover | CoolbeaN | Multi-Way | 7 | 1st December 2010 04:25 AM |
| Repairing Leak Sandwich speaker drivers | jives11 | Multi-Way | 7 | 7th April 2008 07:26 PM |
| Repairing an old McIntosh | namui | Solid State | 3 | 4th May 2005 12:35 PM |
| Repairing my Merdian263, need help | Nui | Digital Source | 2 | 30th April 2005 10:45 PM |
| Repairing Headphones... | Paprika | Everything Else | 2 | 27th December 2003 07:36 AM |
