How to Make Concrete Horns and Enclosures - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 26th February 2012, 11:21 PM   #31
Speakerholic
Cal Weldon's Avatar
Originally Posted by C37 View Post
PS: This thread should really be in the "Construction Tips" section...
OK.
planet10 needs your help:
Let's help Ruth and Dave
Old 26th February 2012, 11:24 PM   #32
Speakerholic
Cal Weldon's Avatar
The only concrete speakers I ever made were with mesh attached to the inside of the plywood cabinet. Yes, that meant there were six pours but what else was I doing that day?
Old 28th February 2012, 08:13 PM   #33
picowallspeaker's Avatar
It's time for a new toy , Cal
Personal Portable 3D Printer
Old 29th February 2012, 05:17 PM   #34
Speakerholic
Cal Weldon's Avatar
I'd love one.
Old 4th February 2014, 05:17 PM   #35
Phenoholic Anonymus's Avatar
Did anybody try Acrylic resin for horn/ moldmaking. It's cheap, non toxic, can be mixed with marble, granite, glassfiber,etc. Looks very promising to me. Costs 6,- euro a Kg or around 4 $ for an lbs. Also known as Plasticrete. Sort of an resin version of Gypsum.
At least it wont leave a big hole in the wallet and a pile of very hard to remove toxic waste if things go south
https://www.youtube.com/watch?v=COOLheMYbrg
Old 18th July 2016, 03:46 AM   #36
Default I made a concrete subwoofer
I cast a concrete subwoofer quite a few years ago. The outside of the mould was particle board. The inside of the mould was a 12*12*12 inch cardboard box that can be torn out though the speaker mounting holes afterwards. I used baby oil as the release agent. A trick was making temporary dividers that get fastened halfway down all around so that when half is poured, screw down a mould panel to close off the side, turn the mould over, remove the other panel, remove the dividers!, and pour the other half. I recall vibrating the thing by striking it with a wooden board many times in succession.
I didn't use metal reinforcement. I gave them almost a week to set.
The advantage of concrete is not only its mass, but also it's great stiffness when cast as a single piece.
Concrete Horns MiWi Multi-Way 53 23rd April 2017 06:44 PM
Concrete Improvement? (Concrete FE168 EZ) Kwast Full Range 9 20th May 2010 09:32 PM
How do I make spherical enclosures? rochmndx Multi-Way 27 21st February 2008 08:44 PM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
ANother way to make curved enclosures. Hybrid fourdoor Multi-Way 5 30th June 2003 10:14 AM
Copyright 1999-2017 diyAudio
