Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 10th February 2012, 11:16 PM   #1
Default 800W Load - Rackmount
I bolted everything to the underside of a slide out shelf...
When not in use, slides fully into the rack, dissapears, and
becomes a normal shelf. But havn't wired anything yet.
The front is organized for series & parallel bus wires to go
through the posts sideways. The hole in the side of each
binding post is the same size as the hole in front.
So, anyways: This is Qty8 of 4ohm 1% non-inductive 100W.
Lead times and prices on >100W were unreasonable, so we
settled for several 100W that can be reconfigured as needed.
These Dales came from Newark.
I used bolts that would normally be countersunk, such that
the top shelf surface is still reasonably flat and unobstructed.
Old 10th February 2012, 11:32 PM   #2
thaumaturge's Avatar
Nice work.
I think such resistors expect some surface heat transfer to make full wattage. Don't know if they will do full spec with just freeair dissipation. A bit of heat sink compound between resistor and chassis will definately help. Just a thought. Also, if you are going to opperate in flip up attitude, a small plastic or sheet metal tent over each resistor will help promote chimney effect free air cooling.
Doc
Ne timeas a facie mulierum ea ignorare
Old 11th February 2012, 12:06 AM   #3
I'm surprised you didn't bolt them to an aluminum heat-sink with a fan on it.
Old 11th February 2012, 01:02 AM   #4
5th element's Avatar
Indeed resistors like that can dissipate much more power on heats-inks.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 11th February 2012, 01:17 AM   #5
The shelf is plenty big enough for a box fan when deployed
Old 11th February 2012, 01:31 AM   #6
nigelwright7557's Avatar
A resistor load is fine for testing.
I would always also test using speakers as they are a more inductive and capacitive load and can cause an amplifier to oscillate.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 11th February 2012, 01:54 AM   #7
As I said first in my comments: Nice work!
Doc
Old 11th February 2012, 01:56 AM   #8
When I have a procedure to follow that calls
specifically for measurements with resistors,
resistors have to be used.
I opted for non-inductive resistors at extra
cost, cause you can always add inductance.
But darn hard to make it go away.
We have speakers too.
Old 11th February 2012, 02:11 AM   #9
I suppose it depends. I have some high power resistors like that bolted to a large heat-sink and on sustained high power tests the sink gets really hot. I am sure that you could easily increase the total sustained dissipation capability by using a better method for cooling, but whether or not this is needed is another matter entirely.
Old 11th February 2012, 02:23 AM   #10
If it needs more of anything, it will get more.
For now, this is probably slight overkill.
Don't go over-imagining that I would use this
at full power 24x7. Its for production testing,
not solid weeks of burn-in or characterization.
Our customers have their own labs for that.
If you are building a load for sustained use,
those considerations are probably relevant.
200w to 800w or am i missing something? djmarvellous Solid State 75 18th December 2007 12:29 PM
WTS: Toroid, 2x42VAC/ 800W Jan Dupont Swap Meet 3 23rd October 2005 10:59 AM
fried 800w audiobahn 1needforspeed Car Audio 10 22nd July 2005 06:03 PM
300-800W 8Ohm Sub Amplifier KostasTheGreat Solid State 23 24th August 2004 03:02 AM
Help , I need a 4CH 800W amplifer rex_wang Chip Amps 10 11th August 2004 01:39 PM
Page generated in 0.11114 seconds (78.25% PHP - 21.75% MySQL) with 11 queries
