Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th February 2012, 09:15 PM   #1
dirkwright's Avatar
Default Carbon Fiber boxes?
Since carbon fiber is electrically conductive, it could, in theory, be used for making electronics enclosures. Of course, the bare fibers have to be exposed at one place at least in order for the panel to be conductive. Has any one used it, or seen it used, this way? Since it's conductive I assume it would also provide protection from RFI, but not EMI.
One place to get ready made carbon fiber sheets:
http://www.dragonplate.com/
Old 24th February 2012, 06:52 PM   #2
von.ah is offline von.ah  United States
von.ah's Avatar
Thumbs up enless possibilities
The samples section of that company is awesome!
One could use the tubing for a small enclosure for a DAC/Amp/Crossover/etc...
Very cool stuff!
Old 9th March 2012, 06:43 PM   #3
something like that is killer! even if it is their veneer
Old 2nd April 2012, 09:52 PM   #4
No protection from magnetic fields. Good protection from electromagnetic radiation; less than -20dB below 1 Mhz but quite good above. Some research shows -80 dB. So, for RFI from cellphones, wifi, microwaves, etc very promising. A good reflector so effective as antennae reflectors (eg dish).
You could incorporate your ground field connection with the CF composite material choice perhaps; eg CF / copper / CF sandwich and bring your connection out via the copper.
For safety treat as metal.
" ... In theory, there is no difference between theory and practice; In practice, there is. ..." - Chuck Reid
A Carbon Fiber store!! DaveThreshold Analogue Source 9 11th May 2009 04:52 AM
carbon fiber cones? thoriated Multi-Way 21 28th January 2009 08:02 PM
carbon fiber earing Instruments and Amps 8 13th March 2007 05:04 AM
How do I use carbon fiber + MDF wood + glass fiber to make speaker? sonyacer Multi-Way 16 10th May 2004 03:57 PM
Cutting Carbon Fiber user510 Analogue Source 6 25th December 2003 04:40 AM
Page generated in 0.06983 seconds (71.80% PHP - 28.20% MySQL) with 11 queries
