| Construction Tips Construction techniques and tips |
#11 |
Sounds like something is amiss with the circuit ground. It seems like you might be getting the signal ground by way of the input cable ground from the source device. When you disconnect the inputs it loses the ground connection. By the way, does it buzz with only one input disconnected or do you have to disconnect both channels.
#12 |
The amp is built as 2 entirely separate monoblocks. Thus if I disconnect the RCA from the right channel, then the right channel will buzz, if I disconnect the RCA from the left channel then the left channel will buzz (I tested this last night just to make sure!).
#13 |
Try removing the AC mains connection from one amplifier and see if the active channel still buzzes. If it does, on that channel reverse the transformer primary winding connections. See if the buzz gets louder. Reconnect the primary leads for the lowest buzz. (Duh, of course you knew that.) Now reconnect the other side and check for which way the primary windings give the lowest noise.
If all else fails place a 100K resistor at the input jack from hot to ground. |
| Dual chassis earthing question | audio_cf | Pass Labs | 3 | 21st April 2006 08:12 PM |
| first I earth the chassis for safety but why do I need to conect it to my ground... | frank2395 | Pass Labs | 4 | 20th May 2005 12:15 PM |
| Non-ferrous chassis and fire safety | KT | Parts | 0 | 14th February 2005 04:17 PM |
