| Construction Tips Construction techniques and tips |
I am interested in building a pair of transmission line (TQWT) speaker enclosures (single-fold Voit pipe) and I have a question regarding the internal wiring between the full range driver and the binding posts. Should the wiring be secured to the inside of the enclosure? I will be using 14 gauge stranded, tinned OFC, 182-strand count.
#2 |
frugal-phile(tm)
It doesn't need to be. What FR are you using? For most 14g is quite overkill. We regulatily use 24g solid.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I favor burying it in the stuffing. The worst-case would be insufficient fastening to enclosure.... it can slap. Only happened to me once, but it drove me mad for a long time until I figured it out. |
#4 |
The FR I'm using is the Merrill DCA5.5 (cast basket) and the enclosure is actually a tapered 8th wave tube design by Ronnie Thackeray of Carolina Audio that was originally for a Feastrex D5NF. I will post pictures as soon as the cabinets are finished.
#5 | |
frugal-phile(tm)
A line may be 1/8th wavelength of something (say Fs?), but as long as one end is closed and one is open it acts as a 1/4 wave resonator. In general, for the DCA i'd is 20+ g solid wire. What kind of amp are you using? dave
#6 |
Here are photos of the cast basket DCA5.5
http://www.flickr.com/photos/7656358...in/photostream http://www.flickr.com/photos/7656358...in/photostream The amp I will be using is the Charlize2 but I am considering (2) PopPulse T-150Pro TA2022 amps in mono block configuration. By the way, I already own the previous model DCA5.5 (stamped baskets) in custom bass reflex cabinets built by Fritz Heiler of fritzspeakers and they sound amazing. I posted a video on you.tube with the speakers powered by a new Topping TP20 MK2 TA2020 amp: Topping TP20 MK2 TA2020 Tripath Amp - YouTube Last edited by MrKTrout; 13th February 2012 at 05:56 PM. |
#7 | |
frugal-phile(tm)
Very nice... same basket as the Neophone.
dave
| Speaker enclosure for Coral 12tx-1 triaxial vintage speaker | crossdrilled | Full Range | 0 | 6th January 2012 09:03 AM |
| Question about speaker wiring | eeyore | Full Range | 4 | 26th January 2011 11:53 AM |
| Speaker Wiring Impedance Question | Rotus623 | Everything Else | 17 | 2nd December 2010 08:39 AM |
| 4x12 Speaker cab wiring question | mytool4u | Instruments and Amps | 28 | 8th August 2007 10:15 PM |
| Help with enclosure and wiring | digdug1168 | Car Audio | 1 | 5th May 2006 08:47 PM |
| Page generated in 0.08597 seconds (76.80% PHP - 23.20% MySQL) with 10 queries |
