| Construction Tips Construction techniques and tips |
Here is a cheap way to make an SO8 to DIP8 adapter if you don’t happen to have those fancy PCB adapters around. To make the adapter you need a DIP8 socket that has opening in the center with square corners. SO8 chip fits pritty perfectly this opening when inserted underneath and stays in place without glue. Center pins (2,3 and 6,7) can be soldered directly to DIP8 socket. Outer pins need some extension and is best done with thin wire wrapped around the pins and then soldered.
#2 |
Very nice job.
#3 |
As a side benefit you get some readily accessible test points, with less chance of causing damage than probing directly on the pins of an SOIC. (Shorting pin 6 to pin 7 with your 'scope probe is NOT a good idea. Don't ask how I know that.)
Or, perhaps better yet, you get some sockets that can accept passive component leads for quick experiments. Dale |
#4 |
The sockets I have at the moment will not fit a SO8 device in its opening. I have plenty of PCB adapters though, just happened to be at the bench when I read this so thought I would try it.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#5 | |
Dale |
#6 |
| Source for so8 IC sockets? | PhopsonNY | Parts | 10 | 30th June 2011 09:33 PM |
| diy db9 to midi adapter cable | audiomachines | Digital Source | 0 | 5th October 2007 10:06 AM |
| tqfp adapter for pcm2706 diy | morpheus82 | Parts | 3 | 7th September 2006 11:15 AM |
| single so8 to dual dip opamp adapter available from BrownDog | morsel | Solid State | 18 | 1st June 2002 06:34 PM |
| Page generated in 0.09555 seconds (75.22% PHP - 24.78% MySQL) with 10 queries |
