Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 18th January 2012, 05:56 PM   #61
KatieandDad's Avatar
Why not just pick up a bit of scrap ally and try tapping a few holes.
Old 19th January 2012, 03:53 AM   #62
Lavcat is offline Lavcat  United States
Lavcat's Avatar
Because I don't have a tap. I don't have any taps at all, cutting or Thredfloer. I've used a tap but not in a long time. Of couse I intend first to try various methods in less good aluminum before I start in on the real panel.
Old 19th January 2012, 09:20 AM   #63
The UK has a variety of cheap carbon steel tapping and threading kits.
Both metric and imperial thread forms in a wide variety of sizes.
This is the cheapest way to start tapping aluminium.
Do not expect carbon taps to tap any of the hard materials.
Carbon is a bit brittle, so you must learn to tap accurately without abusing the tap.
Cheap carbon will not be as accurate as proper taps.
If you require steel tapping and or a specialized hole size or thread form, then you can buy the expensive set of three taps. tapered, second and plug tap. These can also be bought in the various tap types and individually they are not anywhere near cheap. You will weep if you break one.
regards Andrew T.
Broken drill bit in chuck gmphadte Equipment & Tools 14 14th September 2007 04:19 AM
Denon DCD 1520 20-bit or 18-bit? beauty_divine Digital Source 0 9th September 2007 06:41 AM
To drill or not to drill? (a VPI turntable) m.parigi Analogue Source 5 6th January 2006 02:32 AM
24 bit I2S source to 16 bit DAC? chris719 Digital Source 5 18th June 2005 05:24 PM
use digital attenuation to improve 16-bit CD playback on 24 bit DAC capslock Digital Source 7 8th April 2002 11:18 PM
Page generated in 0.07551 seconds (70.86% PHP - 29.14% MySQL) with 11 queries
