What drill bit size to use? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th January 2012, 12:56 PM   #11
kevinahcc20's Avatar
IOW don't use the 7/64 drill as it will leave too little material to form threads of adequate depth. If you can't find the 2.5mm go with either a #40 (slightly undersize) or a #39 (slightly oversize).
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 9th January 2012, 01:01 PM   #12
7/64" drill = 2.778mm.
The 7/64" drill will measure very slightly smaller than this, possibly around 2.765 to 2.773
This leaves far too little engagement.
If you drill oversize due to errors then you could have almost no engagement.
Kevin is right !!!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th January 2012, 06:06 PM   #13
Lavcat is offline Lavcat  United States
Lavcat's Avatar
I have a related question: what size drill should I use to make a hole to pass an M3 screw? Exactly 3 mm, or larger?
Old 9th January 2012, 06:12 PM   #14
vinylkid58's Avatar
Larger.
jeff
Old 9th January 2012, 06:20 PM   #15
In metric, I always drilled the hole 0.8 of the M size. The respective bits are readily available in hardware stores from Metriclandia.
For example M3 drill with 2.4mm, M4 drill with 3.2mm....
Old 10th January 2012, 12:29 AM   #16
Lo_Tse is offline Lo_Tse  Canada
Gentlemen,
Thank you for all the pointers. Much appreciated.
To make a hole for taping, is a dress press absolutely necessary (I know it is much easier) or can one get by with a cordless hand drill?
Lo_tse
Old 10th January 2012, 12:32 AM   #17
nigelwright7557's Avatar
Originally Posted by Lo_Tse View Post
Gentlemen,
Lo_tse
A hand drill might not drill a straight hole so a drill press is much better.
However, I have got away with a hand drill, I was just carefull to keep the drill steady.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 10th January 2012, 12:34 AM   #18
Default A worthwhile thread to read
Drilling and tapping Conrad heatsinks
Old 10th January 2012, 12:52 AM   #19
If you only have a hand drill you can get the closest to square drilling by placing the upright edge of a small engineers square next to the center puched mark for the hole. Use the vertical edge of the square as a reference to keep the bit aligned vertically in both the side to side & fore and aft planes. A drill press would produce a better result but you can get close with practice.
Old 10th January 2012, 01:16 AM   #20
thov is offline thov  Denmark
Working with aluminum there's no need for greasy lubricants - alcohol beats everything else.
Even your 12 year old Jack Daniels will do the trick, but ordinary household spirit is cheaper, cools effectively and evaporates leaving no trace.
Broken drill bit in chuck gmphadte Equipment & Tools 14 14th September 2007 04:19 AM
Denon DCD 1520 20-bit or 18-bit? beauty_divine Digital Source 0 9th September 2007 06:41 AM
To drill or not to drill? (a VPI turntable) m.parigi Analogue Source 5 6th January 2006 02:32 AM
24 bit I2S source to 16 bit DAC? chris719 Digital Source 5 18th June 2005 05:24 PM
use digital attenuation to improve 16-bit CD playback on 24 bit DAC capslock Digital Source 7 8th April 2002 11:18 PM
Copyright 1999-2017 diyAudio
