Construction Tips Construction techniques and tips
What drill bit size to use?
Old 9th January 2012, 02:09 AM   #1
Lo_Tse is offline Lo_Tse  Canada
Default What drill bit size to use?
Hi there,
A real quick question from a newbie. What size drill bit should one use to make holes (on a heat sink) that are suitable to be tapped for M3 screws? It seems that I can only find drill bit in imperial scale? Would a 1/8 (0.125) inch drill bit work for the M3 (0.118) ? Thanks!
Lo_tse
Old 9th January 2012, 02:15 AM   #2
madtecchy is offline madtecchy  England
Default Tap drill size
Hi Maybe this will help.
Ian
Old 9th January 2012, 02:18 AM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Thanks for that, copied it to my pc.
Dont forget to oil the hole the tap will go down to ease the cutting.
I broke two taps before finding that out !
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 9th January 2012, 02:43 AM   #4
jordheis is offline jordheis  United States
jordheis's Avatar
for a 3mm x .5 pitch fastener;
as noted use a 2.5 mm drill, or a close equivalent is a #40 drill.
The Fractional Drill Chart reference
Drill/Tap chart reference
I'm a Groove Puppy
Striving to remove some ignorance every day (always starting with my own)
Old 9th January 2012, 02:49 AM   #5
Ian
Thanks! That's useful. Here in Canada, it seems that I can only find drill bit in Imperial size (e.g. Home Depot) but not metric. Using you chart, may be I should try 7/64 inch (2.75 mm) drill bit for the M3 (3 mm) screws.
Old 9th January 2012, 03:10 AM   #6
jordheis's Avatar
Sure - You can give 7/64 a try on a scrap piece to test how it goes with a tap and fastener. Aluminum being soft be careful to not over torque the M3 fasteners and strip out the hole.
Otherwise go down a fraction and test that too. That's how I would proceed on my stuff.
Remember the tap lube as nigelwright7557 noted. Have a spare tap....
I'm a Groove Puppy
Old 9th January 2012, 03:55 AM   #7
Conrad Hoffman is offline Conrad Hoffman  United States
Heat sinks are usually made out of a gummy aluminum that likes to break taps and machines poorly. If you're going to do much of this, it pays to order drills and taps from a machine tool supplier. For taps that cut threads in blind holes, order spiral flute taps (not spiral point) as those will send the chips back out the top of the hole. Spiral point taps will send the chips forward, but they have to have a place to go. Those are the only two styles one should mess with. For something a bit nicer, order a Balax forming tap. You'll need a very specific (and larger) drill size, but the tap will form the threads by deforming the aluminum. No chips at all and very strong threads. The taps are much stronger than cutting taps and last near to forever. In any case be sure to use oil for both drilling and tapping. Vegetable or animal oils work best so if you don't have a commercial tapping fluid, try a bit of canola oil or bacon grease!
I may be barking up the wrong tree, but at least I'm barking!
Old 9th January 2012, 12:17 PM   #8
Thank you very much for the link. Very comperhensive information!
Old 9th January 2012, 12:24 PM   #9
Thank you for the info and advices. I do have a set of taps purchased from a hardware store, but have not tried it out yet.
Your point on using the spiral flute taps is interesting. I thought, like drill bits, taps would pull the chips back out on top! Good to know. I guess I just have to get a scrap piece to try things out.
Once again, thank you very much for all the info and advices. Much appreciated.
Lo_tse
Old 9th January 2012, 12:29 PM   #10
Metric threads have been made easy for us since they adopted a 60degree thread face angle.
Take the screw thread size and subtract the pitch.
eg M3 0.5mm pitch needs a 2.5mm drill.
In hard materials (steel) you can drill slightly bigger than 2.5mm to make for easier tapping and this gives slightly less engagement.
In softer materials (aluminium) you can drill slightly smaller than 2.5mm to ensure full engagement of the male and female threads.
The extreme form of this are the thread forming taps, rather than the thread cutting taps.
Note "slightly".
The total engagement of that M3 0.5mm pitch is only 0.25mm. Take 10% off that for 0.225mm engagement results in the required hole size being 2.55mm diameter. 80% engagement requires a 2.6mm diameter hole.
Poor drilling technique and poor sharpening of the drill point both result in oversize holes.
Be careful you leave sufficient engagement to give a "strong" thread.
regards Andrew T.
What drill bit size to use?Hide this!Advertise here!
Broken drill bit in chuck gmphadte Equipment & Tools 14 14th September 2007 04:19 AM
Denon DCD 1520 20-bit or 18-bit? beauty_divine Digital Source 0 9th September 2007 06:41 AM
To drill or not to drill? (a VPI turntable) m.parigi Analogue Source 5 6th January 2006 02:32 AM
24 bit I2S source to 16 bit DAC? chris719 Digital Source 5 18th June 2005 05:24 PM
use digital attenuation to improve 16-bit CD playback on 24 bit DAC capslock Digital Source 7 8th April 2002 11:18 PM
Copyright ©1999-2017 diyAudio
