Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 10th January 2012, 01:23 AM   #11
Will this power supply work? If I could use an external power supply that would be great. Would I just run the - and + to a distribution strip (one set of power to the amp another to the LM317 circuit)inside the MP3 cabinet?
Old 12th January 2012, 11:24 PM   #12
Hakimi is offline Hakimi  Malaysia
for your simplest way to power-up MP3 module is 5V right ?
If me, I will use any USB charger which the output is 5V 500mA-1A
and for amplifier, just use normal transfomer with caps. rather using lappy PSU which is based Switching Mode Power Supply (SMPS)...
Just an opinion...
Old 13th January 2012, 08:41 AM   #13
Just an opinion...
Thanks for the tips. I decided to use a smaller internal amplifier. This allows me to use an outboard 12v power supply that I will step down with a 7805 for the 5v.
Thank you all for your help.
Old 13th January 2012, 02:30 PM   #14
welcomes...
previously i have built an intergrated amplifier with preamp and MP3 player
have a look.. https://www.facebook.com/media/set/?...3&l=075c4799a2
This set built for Final Year Project for my diploma..
regards..
Old 13th January 2012, 02:35 PM   #15
KatieandDad's Avatar
Originally Posted by edouble101 View Post
Excellent recommendations! Thank you very much.
I am researching the LM317 and have found this video helpful.
Should the heat generated from the LM317 with a 24v input and a 5v output be a concern?
The data for the MP3 decoder is insufficient to know what the current draw will be.
Generally the lower the voltage, the more current is required.
In that case the LM317 might need a heatsink.
Old 13th January 2012, 02:50 PM   #16
There is a mention of 3W POWER RELEASE - I've no idea what our Oriental friends are talking about there.
If we double that for a guestimate - 6W and add a few watts to 10W we are looking at 2A at 5V.
In this case the LM317T is going to need a serious heatsink.
24-5 = 19V. 19V x 2A = 38W
The heatsink would cost more than a low voltage transformer dedicated to producing the 5V.
Having said that. There are a LOT of old computers on the scrap heap that have heatsinks that are used to dissipating about 60W.
Be careful of USB power supplies - we dont know what current this thing needs.
Old 14th January 2012, 12:13 AM   #17
welcomes...
regards..
Cool project
The 3w power release is the onboard amplification for speakers per channel.
I picked up a 7805. I will be stepping down a 12v power supply to 5v. The MP3 decoder and another gizmo I am throwing in the mix shouldn't draw more than 1.5A.
I ended up buying a Parts Express MP3 decoder a 12v 2a powers supply and a Dayton Audio 15w x 2 amplifier. I also picked up a 7805 and a few other things that you guys will have to wait to see
Once I get this project started I will post pics of my progress (and probably some more questions)
Old 28th January 2012, 01:05 AM   #18
As promised here are some pics of my progress.
I didn't edit text to this pics
Old 28th January 2012, 01:11 AM   #19
5v regulator circuit
Video that I can not figure out how to thumbnail post
http://www.youtube.com/watch?v=5fb9q...e_gdata_player
Old 28th January 2012, 01:19 AM   #20
Question!!!!!
I bought a double sided circuit board at Radio Shack. How can I etch off one side without over etching the circuit side?
Any recomendations on a DIY compact loudspeaker for MP3 PC use juanito Multi-Way 0 10th May 2011 04:12 PM
diy mp3 with harddisk Jempie Digital Source 14 13th February 2010 12:35 PM
Modifying an old Radio to accept an MP3 Player - help needed FoleyF Digital Source 3 25th June 2008 10:03 AM
DIY MP3 Player! ultrachrome Digital Source 7 21st February 2005 04:15 AM
Page generated in 0.12991 seconds (83.01% PHP - 16.99% MySQL) with 10 queries
